how do I wipe the error code so i can start the car
Discussion in 'Generation 1 Prius Discussion' started by evnz, Apr 6, 2013.
  1. evnz
    evnz New Member
    1998 Prius
    I would like to clear the codes so i can try to start the car after i put in newish batteries
    I want to have codes for only things that are wrong
    thanks
    owen
  2. ursle
    ursle Gas miser
    1,049
    192
    NH
    Unhooking the 12v will clear any codes that are not urgent, 10 seconds is a good time to unhook for, any codes appearing after a cold boot will be something to pay attention to;)
    bwilson4web likes this.
  3. vaughnstark777
    190
    33
    Roy, WA
    2001 Prius
    I
    Most auto parts stores have inexpensive obd2 code readers that clear codes as well as read them.
  4. bwilson4web
    16,351
    For the Federally mandated, emissions codes. There are 3x Prius specific codes that an 'over-the-counter' OBD scanner will never read.
  5. evnz
    evnz New Member
    1998 Prius
    Just talked to toyota and the ecu is not talking to there scan tool and they left any idea what to do now
  6. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    I suggest talking to someone with experience working on a 1998 JDM Prius. There are some owners in NZ and Australia that have these cars. I don't know of anyone in North America with a pre-2001 Prius. If the car has OBD2 port like 2001 and newer, check the OBD fuse(s) in the fusebox if a scanner won't communicate...blown fuse may make the scanner not "see" the car.
  7. Prius Mitch
    Prius Mitch New Member
    29
    2002 Prius
    I
    When attempting to restart the car after hooking the negative cable back up, what is the procedure, so that I don't get the triangle? It seems everything is out of whack when I do this.
  8. bwilson4web
    16,351
    When a code or warning comes back on, it means the problem is permanent. Now we can gain some insights if you slowly turn the key from position-to-position. But the 'ambiguity group' (the list of things that could be broken) remains too large to start 'swapping parts.'
    You're really going to need a Prius-aware scanner. These scanners can get the error codes from the half-dozen control computers that operate the car.
