How do the tire air valves affect the inflation pressure alarm?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by domtick, Sep 16, 2015.
  1. domtick
    domtick Junior Member
    Middletown. Delaware
    Just had new tire installed and now noticing that the original stem cap was not used. Alarm is not lit, but wondering if I should try to retrieve the original one, since we notified the tire shop that afternoon.
    .....or purchase a new one.
  2. Mendel Leisk
    41,163
    Are they green caps, from Costco?
    My rule #1 when going in there: take the valve caps off beforehand.
    But anyway, any half-decent cap will be effective. They're mainly to keep the valve clean. And provide a slight second-line-of-defence against air leakage, I suppose.
  3. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    The valve caps have nothing to do with the TPMS warning system. If your original caps were metal and now they are plastic, that's a downgrade. But plastic for plastic, probably not worth worrying about.
  4. Mendel Leisk
    41,163
    OEM are very flat-topped, metallic looking, but actually plastic. I read somewhere metal caps are bad for something, causing valve stems to rust, or?
  5. xliderider
    8,140
    3,274
    Honolulu, HI
    The metal ones I've had were aluminum, so no worries about rust.
  6. Mendel Leisk
    41,163
    Not really up on it, but reading a bit, see some talk about dissimilar metals. If you frequently take them off to check pressures (always a good idea) then not time for anything to seize I guess. But hey, think I'll stick with plastic.
