How do you add the instant MPG vertical bar to the instrument cluster
Discussion in 'Prime Main Forum (2017-2022)' started by bear15, Jul 1, 2017.
  1. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    How do you add the instant MPG vertical bar to the instrument cluster?
  2. john1701a
    john1701a Prius Guru
    12,747
    5,243
    57
    From the settings menu (left/right options uses the right buttons on the steering-wheel), choose the far-right option.
    It's where you access speedometer & clock options. Scrolling down, you'll see "Meter Customization". Select that.
    "Simple/Split Screen" is the feature to edit. Choose "Split".
    HPrimeAdvanced likes this.
  3. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    Many thanks! Also, do you know if there is a way to turn OFF the default so the car does not go into EV mode every time you re-start the car?
  4. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
