How do you adjust headlights on a 2016? Asking for a friend
Discussion in 'Gen 4 Prius Main Forum' started by George W, Jun 28, 2020.
  1. George W
    George W Senior Member
    911
    514
    San Antonio
    My mother-in-law has a 2016 that has one dim side and one blinding side. This is just how she described it to me, she lives 1200 miles away so I can't see for myself. Is there an alignment adjustment that I could explain to her? Thank you.
  2. Elektroingenieur
    2,515
    3,287
    Three Touring
    There is an alignment procedure in the Repair Manual (more info), under Vehicle Exterior: Lighting (Ext): Headlight Assembly: Adjustment. No special tools are required, just a way to measure distances and make markings on a wall, either 25 feet or 3 meters in front of the car.
    Before making adjustments, I’d suggest checking that both headlight assemblies are operating properly. There aren’t separate lamps for high and low beams, just a mechanical shade that moves out of the way when high beams are selected. If the shade or its control wiring has failed on one side, it could cause the effect you describe, with one side bright and the other dim.
  3. ChapmanF
    18,513
    My recollection (from earlier Prius generations) is that reaching down to the adjuster requires a Phillips screwdriver, which maybe isn't a very 'special' tool, but needs to be long enough. (My usual go-to screwdriver is a ratchet handle with a long shaft and swappable bits, but that shaft is to wide to go in there. I bought a long plain Phillips screwdriver just for the purpose.)
    Tande likes this.
