How do you completely remove the carpet from the back?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TonyPSchaefer, Jul 26, 2011.
  1. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    A coworker spilled some liquid in the cargo area, on the carpet and on the back of the back seats. She asked me how to remove the carpeting. I don't know.
    She said that they removed the tie-down bolts, undid some velcro but there's something in the middle holding it down. For fear of damage, they didn't try to pull too hard.
    Has anyone ever removed the back carpet?
    How do you do this?
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    38
    Santa Fe, NM
    Are you talking about the floorboard that covers the HV battery? If so, the difficulty is understandable. There are three plastic clips that hold it in place. If I remember correctly, you have to pop the center one out of the metal, then you can slide the floorboard off the two side ones. It takes some practice to get this off without breaking one or more of the clips.
  3. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I went through this when I installed the Subwoofer. I mounted it to the plastic battery cover. After I pulled it I went for the carpet too, There was one section that gave me grief, I just cut it and tossed it! Amazingly when I put everything back together, the rear seats fit better than before they were yanked out.
  4. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
  5. Mendel Leisk
    41,908
    3rd gen carpetting over the big battery is similar: lots of push-in fasteners in the underside which has some sort of rigid board inside. I used a couple of types of panel removal tools, just worked slow. On reassembly, I left most of the push-in fasteners off (just bagged and labelled them), in case I want to revisit. It was still plenty secure.
    BTW, throwing a cheap blanket in there is good for loose dirt, will even slow down spills. I tuck it under the under floor lid at the back edge, so it doesn't end up jamming the hatch latch.
  6. jdtechtalk00
    jdtechtalk00 New Member
    New York City, NY
    seilerts,
    Boy howdy you are not kidding around about the difficulty of this job. I wanted to take a look at my HV battery one fateful day and I had a bear of a time accessing the infernal thing. I suppose boredom does terrible things to a man :p Anywhoo, the OP may be able to refer to this diagram that illustrates the rear floorboard schematics:
    *Legal good stuff- please note that I do not own this diagram, rather it's the property of toyotapartszone.com. Insert further legal mumbo jumbo here ;)
