How do you do it???
Discussion in 'Gen 3 Prius Fuel Economy' started by wjterry, Aug 21, 2009.
  1. wjterry
    wjterry New Member
    48
    Winchester, KY
    Having purchased my '10 Prius, I have been most pleased with the comfort and performance of the car; however, I must say that I am somewhat impressed with the mpg others have reported as compared to that which I have experienced.
    I drive 45 miles to and from work each day. Thirty of those miles is spent on interstate hihgway and the remainig 60 miles are driven on an excellent two lane road on which I travel at an average speed of at least 55 miles per hour. Many of the posts I read here and elsewhere speak of an mpg of 50, 52, 55 and even greater mpg ratings. My best mpg so far (I've driven about 5,200 miles) has been around 48 with most reading in the 47+ range as measured at the pump not per the instrument display.
    What techniques are you guys with the 50+ ratings employing to reach the full potential of the car's technology? Don't get get me wrong. I am extremely grateful for the 47mpg as compared to the 14mpg I was getting on my Tahoe, but I feel I can do better...I just need to learn how. any suggestions?
    Thanks
    Wes - Winchester, KY
    Odometer Reading Miles Gallons $Cost Refuel Date MPG $Cost per Mile
    16 (fuel added) (mileage)
    365 349.0 7.683 $19.20 6/18/09 45.4 $0.055
    781 416.0 8.597 $22.00 6/23/09 48.4 $0.053
    1168 387.0 8.002 $24.48 6/29/09 48.4 $0.063
    1536 368.0 7.62 $19.50 7/3/09 48.3 $0.053
    2017 481.0 10.023 $25.35 7/9/09 48.0 $0.053
    2407 390.0 8.264 $20.16 7/16/09 47.2 $0.052
    2608 201.0 4.483 $10.17 7/17/09 44.8 $0.051
    3043 435.0 9.155 $21.41 7/24/09 47.5 $0.049
    3238 195.0 4.087 $9.80 7/25/09 47.7 $0.050
    3678 440.0 9.305 $23.25 7/29/09 47.3 $0.053
    4095 417.0 8.778 $21.94 8/3/09 47.5 $0.053
    4511 416.0 8.407 $21.85 8/7/09 49.5 $0.053
    4910 399.0 8.578 $22.29 8/10/09 46.5 $0.056
    5110 200.0 4.24 $10.21 8/15/09 47.2 $0.051
    5522 412.0 8.698 $22.61 8/21/09 47.4 $0.055
  2. Glider
    Glider New Member
    135
    30
    Memphis
    A lot of material has been posted on this already. You may want to start by readint the posts in the "Fuel Economy" forum.
  3. dmvp
    dmvp Member
    364
    Outskirts of Chicago
    One mistake I made with my new Prius, was trying to go slow from stops and then holding speed once I made it to the speed limit. I got low mpg this way.
    After reading a lot on this forum, I learned that it it better to get past the speed limit quickly from stop, and then let off of the accelerator slightly. This increases your mpg (you'll see the bar shoot up quickly) significantly. When you start to slow down a bit, give it some more gas and then let off a little.
    Not sure if this is pure "pulse and glide", but I find it works very well for me, and I'm averaging about 56 mpg with everyday driving.
  4. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    Best advice I've heard is to "drive as if your brakes didn't work". Refers to conservation of momentum. I get in the mid 60's by driving the speed limit and "gliding" or coasting as much as possible. Try to cost as much as traffic and time will allow up to every stop, use the brakes as little as possible. I never use the power section of the HSI, but I live in mostly a rural area, and have not gotten on the interstate yet either. I rather enjoy taking two lane roads where the traffic is less and taking my time driving the speed limit and enjoying the scenery. It's relaxing, and I enjoy the Prius that way.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    What speed do you drive on the interstate? I'm sure that's what's killing you. And if you can slow down a little on the 2-lane that would help too.
    As suggested, check the stickies in the Fuel Economy forum for a ton of tips and explaination of why YMMV.
  6. radioprius1
    radioprius1 Climate Conspirisist
    1,355
    155
    Iceland
    Here are two graphics to help you.
    The first made all the difference to me. Basically when accelerating from a stop I keep my bar in that "pulse" zone. And once I reach my speed I let off the gas and keep the bar in the "glide" zone (although I go out of the glide zone, but still not past the halfway bar). Also like everyone said, drive like you don't have breaks. If you know you are going to be coming to a stop in a 1/4 mile, let off the gas and coast to the stop. Why speed to the stop then slam on your breaks? Same if you are exiting the interstate, etc. Once you get used to driving like that you'll see how poorly/inefficiently everyone around you drives!
  7. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    As reported in many threads, tire pressure can make a big difference. Try at least 42/40.
  8. jay_man2
    jay_man2 jay_man_also
    1,246
    143
    Manassas, VA
    Same here. When I commute to work it's easy to get over 50 mpg doing this. When I work from home, and just run a short trip to the gym or grocery store, my mileage sinks, because the car doesn't get warmed up enough.
  9. clo2guy
    clo2guy New Member
    atlanta
    I
    Just be patient and have fun experimenting with your driving habits over time. For me, getting better mileage has been intuituive rather than toughtful.
    Last summer we took our then new prius from atlanta to chicago and averaged about 45 mpg over the 1400 mile round trip. This summer we made the same trip and averaged very close to 50 mpg. Couldn't tell you what we did differently... Average speed probably about 75 mph on both occassions - sorry y'all, over the years I've adopted Atlanta's drive fast or get crushed mindset.
    Totally agree that anticipation is the most important means of maximizing fuel economy. When you see the light up ahead turn red, lay of the gas.
  10. Glider
    Glider New Member
    135
    30
    Memphis
    To give yourself confidence that you can get over 60 MPG, try this -
    - put in in cruise control at 55 mph then reset Trip A or B, and drive at least 10 mi and write down your ave MPG from the MID
    - turn around and drive the same section of road the same way
    - average your two readings, if not over 60 MPG something may be wrong with the car
    You'll also need these conditions while you are doing the test:
    tires at least sidewall max pressure
    A/C at 78 degrees (not so bad)
    ECO mode
    Once in cruise, if you have to hit brakes, change speed or get out of cruise becasue of traffic, etc. forget the run and try again when you have time.
    Good luck and let us know if you beat 60 MPG :car:
    - g
  11. RickFlashman
    RickFlashman New Member
    141
    31
    Winter Park, FL
    Try this technique.
    1. When on highway, use the ECO screen.
    2. Get to 60 MPH, be reasonable, don't let it go RED.
    3. Move the throttle pedal until the meter is in the lower 1/4 of the white area (gas engine on).
    4. Use the throttle pedal to keep the meter between 1/4 and 1/3 setting in the white area.
    5. The car will settle in to around 60-65 on a flat area, dropping to 55-60 when you climb an exchange and accellerating to 65 when you go down the other side.
    6. Compensate for road variations, goal is to keep speed reasonable 55-65 and keep throttle low, allowing car to use its momentum to climb uphills and regain speed on downhills.
    I do this all the time to get at least 55 MPG on the highway. Now if only they had an option to have a "throttle lock" cruise control...
  12. MaggieMay
    MaggieMay Active Member
    534
    68
    Gloucester, MA
    Coincidentaly, I just responded to the Toyota survey about the DVD that came with the car. I told them that the content should include some tips for how to drive a hybrid for better fuel efficiency. Most of us know the basics of car operation - I wish the DVD helped us get the most from a unique car. 'Specially those that don't know about PC !!
  13. Indyking
    Indyking Happy Hyundai owner...
    1,280
    I don't know... Indy, Chicago, Madison (WI)... it
    Assuming you ride alone with no cargo weight and this is summer, yes, averages bellow 50 MPG are indeed low for the new Prius.
    I wonder: How fast do you drive the 30 mile stretch of interstate? Anything after 75 MPH will kill your MPG.
    I'm averaging 57.3 so far after 3.5K miles driven, mixed hwy and city. This is what I do:
    1- I accelerate slowly. I rarely push the energy meter into the red zone (power zone), in other words, whenever possible, I just take my time to reach the desired speed.
    2- I do use cruise control whenever I'm driving faster than 45 MPH.
    3- I do not use cruise control bellow 45 MPH because I can maximize my MPG by keeping the energy bar as far left as possible by controlling the gas pedal.
    4- I do not rush through traffic lights. I try to control my speed, so I can get as many green signs as possible.
    5- I try to be easy on the breaks. Though breaking recharge the battery, the more you let the car cruise where no gas is needed (like going downhill), the better.
    Hope this helps...
  14. wfolta
    wfolta Active Member
    366
    146
    Washington DC
    2018 Prius
    A lot of us have put a lot of time into giving such hints. I have a thread on "You won't get 50 MPG if..." and there are many more threads out there already. There are just too many possible factors to be able to give you a good answer here.
  15. urlyadoptr
    urlyadoptr New Member
    69
    Plymouth, MA
    I'm not even trying that hard, and on my 33 mi. commute, the computer says I'm getting between 54 and 58 mpg (depending on traffic, etc)... I typically set the cruise at 62 and keep it in ECO mode. About 30 mi. of my commute is highway, although there are some heavy traffic spots.
  16. frogpond1
    frogpond1 New Member
    55
    Connecticut
    Eventually when I get mine I too will be perusing the mileage threads. My commute is around 82 miles round trip. Its mostly highway so I average around 70mph it will be interesting to see what I get at this speed.
  17. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    I also think it depends if you live in a hill area or a flat area, I would just be happy with the saving you are getting now,
    In the future when gas goes up and everyone is complaining that it is too pricey to drive you can wear a smile:D
  18. patsparks
    10,664
    567
    Adelaide South Australia
    Maybe Toyota could include the URL for PriusChat on the DVD so people can log on to the internet and find all the good stuff on PriusChat! This way everyone can get the latest tips.
  19. nineinchnail1024
    nineinchnail1024 New Member
    280
    40
    New Orleans
    I always use eco mode. I accelerate quickly, but never let the eco light kick off. When coming to a stop, I coast for a while, and use just enough brake pressure that the regen indicator on the dash never goes fully green. This requires longer, slower stops. Follow speed limits, use cruise control whenever possible (even at 35 mph). 58mpg is easy for me...
    now if I could just get the wife to quit KILLING my mileage whenever she gets in the car.
  20. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    Being a Hypermiler before buying the Prius made a huge difference on my fuel economy for my first tank.
    1. From a stop try to use the battery up to 15-17 mph before lighting off the engine. Then take it smoothly up to speed staying out of the pwr range.
    2. Leave the car in Eco all the time
    3. As said before AC at 78 will help a lot
    4. Cruise control on the highway maximum speed of 65 mph. Speeds between 50-60 mph give the best fuel mileage on the highway. Don't be shy about parking yourself in the right lane and driving 60 mph in a 65 mph zone.
    5. You have to learn to have a light foot and anticipate what is ahead of you. You don't drive 45 mph right up to a red light, you back off early and coast using the regenerative braking as much as you can up to the light.
    6. Tires at a minimum pressure 42 psi front 40 psi rear.
    BTW steep hills will kill your fuel mileage unless you really work for fuel economy. With the III be happy with EPA and and anything more is a bonus.
