how do you engage/disengage "B" Mode?
Discussion in 'Gen 2 Prius Main Forum' started by ghomner, Oct 10, 2008.
  1. ghomner
    ghomner New Member
    37
    Ferndale, Michigan
    I'm reading the unofficial Prius manual and it mentions "B" mode but so far hasn't described how one engages this. It sounds very useful when going down steep hills.
  2. pdhenry
    pdhenry It's HEEERE!
    406
    PA
    If you look at the shift lever it has a "B" position - it's straight down from it's normal position. When the car is in D mode move the lever straight down to the "B" it goes into B mode. Nothing will happen when you go to B when the car is in P or R.
  3. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
  4. jdenenberg
    jdenenberg EE Professor
    3,852
    1,847
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Moving the lever to any other position (D, N, P ...) will take your Prius out of "B" mode. Note that you will get lower MPG when using "B" mode as it uses "Engine Braking" to dissipate energy.
    JeffD
  5. ghomner
    ghomner New Member
    37
    Ferndale, Michigan
    I thought B was Park?
    So you slide the shifter to the left and then push up for Reverse, down for Drive. And while in drive if you press down again you are in "B"? Where's park and neutral?
  6. diamondlarry
    diamondlarry EPA MPG #'s killer
    559
    Elkhart, IN
    Park is the rectangular button with the big "P" on it. Neutral is when you slide the lever to the left and hold it there for ~.2 seconds; just like the diagram shows.
  7. ghomner
    ghomner New Member
    37
    Ferndale, Michigan
  8. diamondlarry
    559
    Elkhart, IN
