How do you open up the vanity light?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by biglew8, Apr 20, 2017.
  1. biglew8
    biglew8 Active Member
    170
    114
    Seattle
    I can't figure out how to pop out the vanity light (above visor) to get the light bulb out. I know the gen 3 has a clip towards the inside of the car that releases the housing. I tried all sides and still can't get it out.
  2. hchu1
    hchu1 Active Member
    316
    127
    Houston, Tx.
    2014 Prius v wagon
    There is a slot to the left of the 6 o'clock spot for a flat blade screw driver.
  3. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    I used a very thin steel rule, taking care not to damage the plastic lens. Good luck!
  4. biglew8
    170
    114
    Seattle
    To remove the housing or the plastic lens?
  5. biglew8
    170
    114
    Seattle
    Do I remove the plastic lens or the entire housing?
  6. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    The YouTube video I saw was just the lens
    SM-N910V ?
    #6 windstrings, Apr 20, 2017
    PriusVe30 likes this.
  7. hchu1
    hchu1 Active Member
    316
    127
    Houston, Tx.
    2014 Prius v wagon
    Plastic lens, to remove the housing there is a slot just above the 12 o'clock position.
  8. biglew8
    170
    114
    Seattle
    That video is for Gen 3 model. The vanity light is the one that turns on by sliding open the visor mirror. I tried popping out the housing like this video and couldn't get it out.
  9. biglew8
    170
    114
    Seattle
  10. biglew8
    170
    114
    Seattle
    I think I somehow got the housing to be a little loose when I tried popping it out from each side. It's not tightly against the headliner anymore. Any way to fix this?
  11. hchu1
    hchu1 Active Member
    316
    127
    Houston, Tx.
    2014 Prius v wagon
    In your picture there is a slot just above the 12 o'clock position where the housing meet the fabric, use the same screw driver and it should pop out.
    I believe the housing has some metal clips that hold it against the fabric liner, you should be able to bend them outwards a little to get more tension.
  12. WilDavis
    2,492
    2,153
    49
    Just the lens. There's a video on youtube (replacing wedge-bulbs with LEDs), check it out!
  13. WilDavis
    2,492
    2,153
    49
    It's rather tight, but if you're careful it will come out
  14. Ozzbo
    Ozzbo New Member
    29
    Austin
    Were you able to fix it back? Thanks.
  15. Ozzbo
    Ozzbo New Member
    29
    Austin
    Hello. Can you, please, direct me how to get the light housing out and then put it back? Thanks.
