How do you quickly measure amp hours of capacity in modules?
Discussion in 'Gen 2 Prius Technical Discussion' started by dpeverhart, Aug 7, 2016.
  1. dpeverhart
    dpeverhart Member
    126
    23
    I
    Can someone recommend a product to measure amp hour capacity in modules?
    Thanks,
    David
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    Most RC hobby chargers will do this. They have charge/discharge cycle and discharge/charge cycle
    capability. So, if you want to find out the amp hour capacity of a module, this is a fairly foolproof way.
    And generally speaking, it's not a quick method because it takes quite some time to discharge a
    fully charged module to empty.
    The Gen II Prius individual battery module replacement thread by ryousideways is the best place to look for details
    on how to do this. It's a very long thread but well worth the time. The thread lists about every
    type of RC hobby charger available. The reason I'm directing you there is primarily because
    the price of RC hobby chargers vary from $30 to $300 so one size definitely does not fit all.
    DIYaddict likes this.
  3. BillG
    BillG Junior Member
    Edmond
    Will the hobby charger tell ypu where the current ah is before you start?
  4. ChapmanF
    15,614
    You might think of a module as a jar you can't see into. You can't see what its capacity is, or even how much is in it right now. You can pour it all out, and see how much comes out (but that doesn't tell you its capacity, because you don't know how full it was when you started). But then you know it is empty, so you can start filling it. This doesn't really tell you the capacity either, because charging a module isn't exactly like filling a jar; there are charging losses, so you pour more in than what ends up being in the jar.
    But you can tell when it's fully charged, and then you can pour it all out again and measure what comes out, and now you know its capacity.
    The typical hobby chargers can do most of that for you automagically.
    -Chap
