How do you Shift to Neutral Without Starting Engine
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by trmaddux, Sep 28, 2004.
  1. trmaddux
    trmaddux New Member
    I am repairing a 2004 Prius that has front end damage. The radiator is removed so the gas engine and inverter have no cooling. I need to roll the car and cannot do so since it is in park. My question is how do I get the car to stay in neutral? I would like to do so with the 12v battery disconnected so I do not set the airbgas off when I arc weld the frame.
    Thanks
  2. KMO
    KMO Senior Member
    1,523
    401
    Finland
    2023 Prius Prime
    You can't put the car into neutral unless it is in IG-ON or READY mode, which will mean having the battery connected (or, equivalently, jump-start leads). There is no manual override, according to the Emergency Response Guide.
    IG-ON mode is obtained by pressing the power button twice without your foot on the brake. The LED will be amber. The engine and hybrid system will not start in this mode. Then just move the shifter to N and hold it there briefly. If you turn the power off, or disconnect the battery, the parking pawl will reengage automatically.
