How does the 2011 Prius TPMS work?
Discussion in 'Gen 3 Prius Technical Discussion' started by Mopar, Feb 15, 2012.
  1. Mopar
    Mopar Junior Member
    Fort Worth Texas
    There are several questions I would like to ask about the TPMS.
    Where is the sensor located? It would seem it would have to be in the wheel, the valve stem, or the tire.
    Does it transmit a code on an RF signal to a receiver somewhere on the car?
    Where does the sensor get it power?
    When I replace the tires will the sensor have to be reset to the car.
    This is my first car with a TPMS and I don't have a clue about it.
    Thanks for any answers.
    Roger
  2. Mendel Leisk
    38,726
    It's behind the valve stem.
    I believe so.
    A long life battery. Likely not that long, though...
    New tires with new sensors likely will require a trip to the dealership, and they usually charge. And then, if this is a seasonal change, say snow tires, it will be a twice yearly chore.
    OTOH, you don't have to do anything. For example, you could put on snows without sensors. Or replace tires on the OEM rims, and just leave the sensors off. This will cause a small light to come on on the dash, but that's all.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    As an alternative, Schrader now makes a programmable TPMS sensor that can clone your existing ID numbers. This way no reprogramming is needed when you switch from summer to winter and back. It's pretty new, so some tire dealers may not have heard about it. Point them to this site:
    http://www.ez-sensor.com/
    Tom
    2 people like this.
  4. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Just to clarify--if you replace the tires (and not the wheels), you just need to reset the TPMS with the button under the dash (instructions in owner's manual), like you should every time you add air to your tires. Trip to dealer only required if you want a different set of sensors "paired" with the car.
  5. pjksr02
    pjksr02 Active Member
    532
    225
    Connecticut
  6. hlunde
    hlunde Member
    419
    74
    Some vehicle manufacturers allow the owner to initiate a "re-learn" procedure if new TPMS sensors are installed. This includes many US manufacturers and most European, but unfortunately not Prius. See Ford instructions (attached) as an example.
    Snap-On says this about their TPMS rest tools:
    The TPMS1 also allows users to relearn (a.k.a. retrain, reprogram, reset) the TPM system on most American and European vehicles. It will not, nor will any other RF based TPMS tool, relearn most Asian branded vehicles. On most models, the Asian OE manufacturers designed their relearn procedures to require an OBDII compliant scan tool that will communicate directly with the TPMS ECU/ECM. This is because, as part of their relearn procedure, Asian OEMs require the TPMS sensor ID numbers be manually registered to the ECU/ECM.
  7. pjksr02
    532
    225
    Connecticut
    I still think it's a shame Toyota didn't figure out a way to incorporate an owner-initiated re-learn procedure.
  8. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    The receiver is in the hatch area on the drivers side just above the fuel filler (just higher than the top of the tail-lamp).
    Note that when you replace the tyres you don't have to actually do anything if you run the new tyres at the same pressure as the old ones.
    The sensors are part of the valve stem, inside the wheel. When you get new tyres warn the techs. that the car has sensors. Once they know they won't damage them. Each sensor has its' own number which has to be entered into the tyre pressure monitor ECU if they are changed. This requires proper equipment. Some tyre stores have it but all dealers do. Each sensor is built with a lithium battery inside. It's not replaceable.
