How does the BMW i3 handle so well on such narrow tires?
Discussion in 'Fred's House of Pancakes' started by ggood, Apr 23, 2015.
  1. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Tire Tech: How does the BMW i3 handle so well on such narrow tires? - CNET
    "The EP500's larger diameter and circumference mean that this tire has a slightly larger contact patch when measured front to rear. This makes up for the compromised width and means that when it's time to turn, there's still enough contact patch to provide adequate grip. On the road, the electric Bimmer's seat-of-the-pants performance felt as good as any of its wider-wheeled competition."
    Comments?
  2. Former Member 68813
    3,524
    981
    US
    last time i checked, bikes handled very well with skinner tires. i'm thinking we're going back to bike tires on cars.
  3. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
  4. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    The battery is located very low in the i3. This creates a low center of gravity. Which improves handling.
    I looked at the i3 until I read about its tendency to wander around. Its not very BMW like stability is a BIG turn-off.
    Also the CARB restrictions make the Range Extender ICE option a joke. People report not being able to climb hills after 60 to 70 miles on battery only use. You have to be less than 25% charge before the Range Extender will kick in.
  5. bwilson4web
    15,524
    The larger diameter reduces:
    • tread flex angle - a major source of rolling drag, less flex angle from a larger diameter reduces hysteresis loss
    • slower rotation - the friction torque remains the same but the energy loss is proportional to distance traveled, the rotations
    • reduced profile drag - a narrower tire has less profile reducing the aerodynamic drag
  6. orenji
    orenji Senior Member
    5,884
    3,486
    That is what BMW is good at, great handling cars!
  7. Mike500
    Mike500 Senior Member
    2,593
    764
    Gross altiger autos commen neuer aus Deutschland.
  8. orenji
    5,884
    3,486
  9. Mike500
    2,593
    764
    That's the phrase from the Chrysler 200 TV commercial.
    "High quality cars come only from Gemany."
