How does the prius do on highway ?
Discussion in 'Gen 3 Prius Fuel Economy' started by MSF1344, Jan 5, 2020.
  1. MSF1344
    MSF1344 Junior Member
    61
    UK
    Active
    Hi , I am driving in highway everyday but when my foot is on throttle the battery is charging all the time and when I took off my foot the charging is stopping . Is this normal ? i can see the battery is full but still charging . so i think is something wrong .
    Ferls80 likes this.
  2. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    I'm not sure I completely understand the question.
    On the highway at a steady cruise at normal speeds on level ground, the car would typically charge the battery since it wants to run the engine at the power level that gets the most out of your petrol. That throttle opening is usually more than you need for that speed, so the excess energy goes into the battery until the battery gets so full that the car decides it better use that electricity so it has room if you slow down.
    If you take your foot completely off the accelerator, the car will coast and put kinetic energy into the battery (charge the battery) to simulate the slowing you get with a regular gasser. The amount and direction of flow of the electricity will vary with the throttle opening, the battery's state of charge, the slope of the road, the wind, the engine temperature, and a boatload of other factors.
    If something is wrong, the car will announce it with a warning light or message. This is a car that's both extremely care-free and also extremely fascinating.
    #2 jerrymildred, Jan 5, 2020
    MSF1344, scona and AzWxGuy like this.
  3. MSF1344
    61
    UK
    Active
    Thank you very much .
    jerrymildred likes this.
  4. Grit
    Grit Senior Member
    6,148
    4,057
    Wilkes Land
    From your logic, it shouldn't charge the battery when you take your foot off the accelerator because the battery is full.
