How easy to steal a Prime by hacking Keyless feature?
Discussion in 'Gen 4 Prius Main Forum' started by The Big Sleaze, Jan 19, 2024.
  1. The Big Sleaze
    286
    63
    'frisco
    2020 Prius
    Two Eco
    When I bought my 2020 Prime a few years ago I was hearing its pretty locked down and they would basically need a tow truck to steal it. Does the info in the youtube apply, and is it now fairly easy to hack and drive off in a Prime?
    Any high tech add-ons or other security improvements you recommend?
    I hear with "The Club" its pretty easy to just cut the soft steel of the steering wheel.
    If you lock the brake pedal they can still drive using the E-Brake. I've done that on an old van that only had one hydraulic system and popped a cylinder. Not that tricky, TBH, as long as there is no other traffic. Lock BOTH brake pedals? But to what if cutting the steering wheel is easy? A "to the floor" type lock on BOTH pedals? Seems like a lot of hassle fussing under there. You know you wont be doing that consistently.
    49,401
    Don’t buy the hype
    Harters likes this.
  3. Doug McC
    Doug McC Active Member
    999
    375
    Midwest
    2022 Prius
    Simply put your fob to sleep if you worried about it. No need for some high tech solutions.
