How far can I drive with the ABS/Brake lights on?
Discussion in 'Generation 1 Prius Discussion' started by ronlewis, Aug 28, 2024 at 5:21 PM.
  1. ronlewis
    ronlewis Active Member
    896
    182
    texas
    2001 Prius
    I have a car in Denver I'd like to drive 1000m to Houston. Runs/drives just fine. I powerbraked it to charge up the HV battery, so pretty sure it has standard brakes. What are the chances it'd make it? I drove another car home from Atlanta, and it had battery issues along the way. probably unrelated, but maybe a regenerative braking issue? Anything about ABS failure make the battery discharge?
  2. ChapmanF
    15,883
    Depends on why they're on. Why are they on?
  3. ronlewis
    896
    182
    texas
    2001 Prius
    LOL, I knew someone would ask that. IDK. Usual doofus mode - got distracted, got rushed, and left without getting codes. Then, meant to go back, but got tired of the driving and traffic. Which codes would make it unsafe to drive? I'm thinking if I see no signs of leakage, reservoir is full,I hear the pump turn on and then off with the key on, and the standard brakes seem to work as usual - it's OK to drive home. Kinda like if the fluid controls all seem to be working, I can drive it.
