How far do you go when the fuel gauge blinks?
Discussion in 'Gen 3 Prius Main Forum' started by HLF-DZN, Feb 7, 2013.
  1. HLF-DZN
    HLF-DZN Junior Member
    23
    St. Louis, MO
    I'm new to the Prius. Just bought a 2010 last week. Trim II.
    I read on one of the threads that when the fuel gauge light starts blinking it means "stop and get gas." I thought they were being funny, but I wasn't completely sure. So, on my first day, the light started blinking. In a panic, I pulled into the first station as quickly as I could. It only took 9.5 gallons! If my calculations are correct, then I still had about 2.4 gallons in the tank -- or about 100 mile to go at my current pace.
    So my questions for you is not how far CAN you take the tank down, but how far DO you take the tank down.
    Do you take the tank down until it blinks? If so, how many miles do you go after it starts blinking?
    I'm not looking to break any records or push the envelope, but I'd like to adopt the method that you experienced drivers have been using.
    Thanks!
  2. Danny
    Danny Admin/Founder
    7,093
    2,107
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    I typically used to know that I could go 100 miles after the last pip started blinking. It's a conservative gauge :)
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    And yes the forum matters, as my Gen 2 once ran dry in 7 miles from when I had a blinking Pip, while my v has about a one and a half gallons when it lights the low fuel light.
  4. HLF-DZN
    23
    St. Louis, MO
    I see a lot of threads about not running the tank dry, or too low, etc. But then so many people are talking about getting all the extra mileage on a tank. 600, 700, 800 clubs. They MUST be running it pretty close to dry.
    What does the "average" Prius Gen III driver do? What is your modus operandi?
    I'd appreciate a large sample of responses. Thanks.
  5. ElectronFlux
    ElectronFlux Junior Member
    32
    Mars
    I've gotten as low as 7 miles to empty as indicated on the display. That fill-up was 9.88 gallons according to Fuelly
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    No Prius gets better gas mileage by running on empty. Very few of us can 'hold it' for over 600 miles any way.
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    When my gas gauge starts blinking, I pull over and sleep it off....
    But I'm driving a Honda Fit, and the gas gauge isn't suppose to blink....so never mind.
    KK6PD and xs650 like this.
  8. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    If I'm in my normal driving area with lots of gas stations I normally switch the trip readout to miles remaining. There are between 19 and 30 miles remaining in mine at that point. If I have been driving steadily on level ground with no or mild corners then about 19 or 20 miles, if I have rocked the gas tank with spirited driving or in and out of steep driveways, then closer to 30 miles. I usually get gas at fairly close or just past 0 miles remaining. If I'm not near a gas station and confident that there are gas stations up ahead I have gone 30-40 miles past 0 miles remaining.
    My Gen III car takes a about 9.7-9.8 gallons at 0 miles remaining so I have 2 gallons left then.
  9. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    My PiP tank is slightly smaller but running the tank close to empty is just asking your fuel pump to work harder and to break sooner. As soon as I hit 1 pip, I fill up at next opportunity at my usual gas station. Since my commute is 106 miles round trip, that is the maximum distance I would go. That only happened one time and I filled up 8.7 gallons, the most I ever filled on 1 tank. That means I had 1.9 gallons remaining. I could've gone another 150 miles combined EV and HV. I see no reason to push it based on fuel pump longevity.
    How far can your car go on empty? - SFGate
  10. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    I generally fill up near home at about 100 miles remaining as I have a 92 mile roundtrip commute. On trips I start looking for gas at 50 miles remaining. In the winter, I try to keep the tank at 1/2 full or higher.
  11. HLF-DZN
    23
    St. Louis, MO
    Why keep it 1/2 full in the winter?
  12. car compulsive
    741
    274
    Michigan
    Helps prevent condensation in the tank due to temperature changes, especially when the car may not be driven for a week due to bad weather.
    OceanEyes likes this.
  13. attyjeff
    attyjeff Member
    153
    40
    I have gone to 10 miles or so left on the display, I know not smart but needed to get closer to home.
  14. retired4999
    2,652
    625
    Eau Claire, Wi.
    I fill when 2 pips left! never worry! :D
    ralleia, OceanEyes and KK6PD like this.
  15. harp3333
    harp3333 New Member
    I have gone as low as 3 miles of range left...one pip was blinking...filled up with 9.8 gal (I always stop when the pump clicks off and never try to squeeze more gas in). I assume then I have about 100 miles left to go before running out but am not prepared to "test" it. I average 48.5 mpg over ~400 miles of range on a fill up.
  16. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    The smartest answer in this entire thread. Running out of gas in a Prius is a bad thing! Just fill at 2 pips, you will NEVER run out! Why take chances you don't have to!!!
  17. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    My friend ran his PiP until empty. He went 150 miles with the light blinking.
  18. Munpot42
    Munpot42 Senior Member
    1,391
    543
    Santa Monica, Ca. 90405
    Fill up at 2 pips normally, don't need the drama.
  19. dwhopson
    dwhopson Junior Member
    Greensboro, NC
    2016 Prius c
    Are you referring to '0 miles remaining' in reference to the blinking pip on the gas gauge OR the distance-to-empty (DTE) gauge?
  20. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    The DTE. It is a stabler reading. The bar will start blinking on mine with anything from around 19 to 30 miles on the DTE depending on turning, braking, slopes etc. The DTE reading doesn't change as easily. I think the DTE reading is better damped by the computer
