how good is the heater?
Discussion in 'Prius v Main Forum' started by sambb, Jan 2, 2012.
  1. sambb
    sambb New Member
    17
    I live n cold weather (near chicago often times)
    How good is the heater in cold enviorments? How long to heat car up?
  2. Sabby
    Sabby Active Member
    295
    127
    SoCal
    We live in upstate NY off of Lake Ontario. The engine heats up quickly and heats the cabin well. To heat the cabin quickly stay away from the Eco setting. It will cost you more fuel but does heat up more quickly and runs the engine a bit more when cold. In a mile of driving from cold we have pretty good heat.
  3. easted
    easted Junior Member
    64
    Pillow PA.
    2018 Prius
    Very good heating in cold weather.
    49,492
    as good as any car i have driven. but, your mpg's will decrease due to the cold weather and the engine running more.
  5. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    What's a "heater"?
  6. Tony420
    Tony420 New Member
    San Diego
    The heater in my prius is faster than my honda fit's and my nissan truck also.
  7. bisco
    49,492
  8. prj
    prj Member
    OH
    The heat comes on fast. Putting the climate control on Auto, the fan stays off until there's some heat available, then the fan speed keeps increasing as the coolant heats up, until the cabin is warm.
    One reason for the fast heat: A coolant loop picks up exhaust heat.
  9. MrBillTulsa
    MrBillTulsa Member
    174
    35
    In the hills west of Tulsa
    Great photo, prj! A picture speaks a thousand words!
    I presume that the exhaust to coolant heat exchanger serves to warm the coolant even when cabin heating is not called for?
    Brilliant!
    :eek:
  10. MrBillTulsa
    MrBillTulsa Member
    174
    35
    Also, by the way, is this an accurate depiction of the Gen3 exhaust components? What would be the names of the 4 "cans" in the exhaust path?
    I'm guessing converter1, converter2, heat exchanger, muffler, no?
    :eek:
  11. DBS
    DBS Junior Member
    37
    Staunton, VA
    Four Touring
    It was 14 here this morning and the heater did just fine in my v
  12. Flyman
    Flyman Junior Member
    64
    Packwood, Washington
    We live in the foothills of the Cascades and when it was in the high 20's and low 30's it heated the car just fine. Add the heated seats and it's sweet.
  13. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    That's when you open the window.:D
  14. CalgaryPriusv
    CalgaryPriusv Junior Member
    Calgary Alberta Canada
    Heats up quickly and keeps me warm even when driving in -25celcius temperatures. (That's really cold by the way)
  15. Donrim
    Donrim Junior Member
    Illinois
    Also the Prius v has 3 positive temperature coefficient electric heater elements attached to the water heater core which can provide immediate electric heat even before the engine coolant is warm enough to provide heat.
    From one to two to all three electric heating elements are engaged dependent on outdoor temperature, engine coolant temperature, engine speed, air mix setting, and electrical load.
  16. smokiejoe
    smokiejoe Member
    178
    30
    PA
    Heater works pretty well in Cooold Pennsylvania.
