How hot is your heat?
Discussion in 'Prius v Main Forum' started by Joe I, Mar 19, 2020.
  1. Joe I
    Joe I Junior Member
    VA
    2013 Prius v wagon
    Just really quickly, I've never owned a Prius before. I replaced the engine (details in the JDM engine swap thread in a different Prius V subforum here), used the Airlift tool to draw in new coolant, and I have what I would call 'fairly warm' heat, maybe around 80 or 90 degrees, when the engine is warmed all the way up and the heater is set on HI. This is with the A/C off and yes, I changed the cabin filter.
    I'm unsure of just how "hot" the heat is on these cars. If this was a normal car, I'd say the heat was set somewhere in the middle of it's range. Can somebody advise? If the heat should truly get HOT, then I'll try backflushing the heater core under suspicion of something like Stop Leak plugging it up.
    49,380
    are you in eco mode?
  3. Joe I
    Joe I Junior Member
    VA
    2013 Prius v wagon
    Yes, Eco mode
    Edited to add that I'm not selecting a mode when I start the car, so assuming Eco is the default, that's what I'm in.
    #3 Joe I, Mar 19, 2020
    49,380
    put it in normal or power mode and see how it is. eco suppresses hvac
  5. Joe I
    Joe I Junior Member
    VA
    2013 Prius v wagon
    OK...I didn't even realize it had a normal mode, I thought it was either Eco, Power, or EV.
    I'll give that a try tomorrow, thanks very much!
  6. rjparker
    rjparker Tu Humilde Sirviente
    7,918
    4,680
    Texas Hill Country
    It will quickly heat up to the temperature you set and no more. Normal is Eco toggled off. Watch the indicators in the top right of the dash.
  7. Joe I
    Joe I Junior Member
    VA
    2013 Prius v wagon
    I set "HI", which I figured would not set an upper limit on heat, meaning the cabin should get uncomfortably hot. It gets warm, but not hot.
  8. bisco
    49,380
    and it's not even cold out, relatively speaking
