How I Recondition Cells
Discussion in 'Gen 2 Prius Main Forum' started by tracy ing, Jun 19, 2022.
  1. tracy ing
    tracy ing Active Member
    384
    167
    wash dc
    My reconditioning process does not care about cell temperature or cell swelling. If they swell or get hot, they have issues to begin with and probably wont recover during the process.
    My process uses a 1C charge and discharge, 6.5 amps.
    I discharge at 6.5 amp load down to 6.0 volts.
    I charge at 6.5 amps to delta voltage end of charge, that signal being a 400 millivolt drop in voltage.
    I ignore voltage completely, some go 8.84 volts, some go 9 volts, none ever go over 9.25 volts.
    During the initial charge, I will check the cell near end of charge and if there appears a lot of swelling I may disconnect the charger but it has been rare that I see this, some swelling is ok with me, excess is when it looks like it is really distorting and may gas.
    On subsequent charges I am unconcerned, if it swells or gases it had issues to begin with and salvaging it will probably just put a bad battery in a pack that will fail early.
    I use one charger and one discharger, it takes about 36 hours to get through a cycle just due to charge times of about an hour a battery. That provides any rest period needed, I discharge as soon as charge is complete.
    When I started this a decade ago, I used a VECTOR brand 2, 6 10 amp 12 volt lead acid battery charger and a meter, and that worked just fine, I would just check the meter and look for end of charge and prepare to stop the charge when I saw voltage stall and wait for the pending drop in voltage.
    I used 6 amp charge and sometimes 10 amp, I never saw any reason not to use 10 amp in my use of that charger, the only reason I stayed with 6 on that charger was a fluke in the software in that charger that turned it off exactly one hour into the charge if it was set at 6 amps, so I took advantage of that fluke, I could not use 10 amps as that would be way overcharged before it would cut off in one hour.
    I went to an automatic charger just to free me up from watching the process. I have never had a mishap explosion rupture or fire.
    I take a half inch square of paper towel and lay it on the relief valve, I press it hard so it makes a circle print on the towel, but i do not insert it, if the battery gases it will blow the towel off and I will know it gassed. They rarely ever gas.
    Three cycles is usually enough and the returns on additional cycles are usually not worth the effort.
    Packs I have built this way last for years. I have yet to intervene on one installed in a prius.
    I use a Hitec X1 Pro charger with optional power supply to charge (it can discharge too but not at 6.5 amps)
    The Hitec is no longer available.
    I use a West Mountain CBA II for discharging, and optionally, to monitor and graph charging of the Hitec.
  2. PriusCamper
    PriusCamper Senior Member
    11,055
    4,499
    Pacific Northwest, USA
    Meg&Bear, Prius Rising and tracy ing like this.
  3. tracy ing
    384
    167
    wash dc
    Yep, thats why I go to 6 volts, 1 volt per cell
    Meg&Bear likes this.
  4. PriusCamper
    11,055
    4,499
    Lol, That's barely even the first round of discharge in my book... The best packs I ever rebuilt were a module discharge at a 1/4 amp constant down to 0.1v per cell or 0.6v total discharge per module on 3rd round and 0.00v briefly works equally as well as long as you are below 1/4 amp.
    You don't need any of this madness if you've spent tens of thousands in lab grade electronic gear which can achieve the same results at a much lower feedback driven tapered discharge / much different voltage reduction protocol.
  5. tracy ing
    384
    167
    wash dc
    lol how many years does that take ?
    I can usually get a dead pack back in the same week and so far they last many many years, with a few hundred in equipment
  6. Tombukt2
    Tombukt2 Senior Member
    8,916
    1,553
    Durham NC
    So you're charging each cell or module at a time or several other time or what's happening I've got a charger that wants to charge all the modules together that likes 336 V I think the charger is set up for DC 2.4 A. And the discharger I have uses a halogen light bulb or a halogen work light I think that might be more than 6.5 amps but I'm not positive I have to go look it's the Venice hybrid charger and discharger
  7. tracy ing
    384
    167
    wash dc
    I'm charging one 7.2 volt battery at a time
  8. tracy ing
    384
    167
    wash dc
    So I decided to apply PriusCampers algo to mine and see what happens
    I chose battery 22
    It had the following over 3 cycles using 6.5 amp charge discharge to 6 volts
    1- 2.682 AH
    2- 3.81 AH
    3- 3.399 ah
    So it actually lost capacity on the third cycle.
    I then further discharged it at 6.5 amps to 3 volts. It had a surprising runtime of 1 AH until it finally knife edged and went over the cliff
    I recharged it at 6.5 amps
    Then discharged it to my 6 volts.
    It had a resulting AH capacity of 4.727
    So that indeed does seem to release some hidden capacity back into the working area of the battery.
    I have a few more operating below the minimums in this pack so I can test further and see what happens when a single additional discharge to 3 volts at 6.5 amps is applied to them
    Thanks camper
    Meg&Bear and Goneballistic like this.
  9. tracy ing
    384
    167
    wash dc
    I made a copy of the google sheet and linked it in case anyone wants it for their use
    Go to bottom and click...
    Sheet 1
    Copy To
    New Spreadsheet
    Click Open Spreadsheet on the dialog that pops up
    #9 tracy ing, Jun 19, 2022
    Meg&Bear and PriusCamper like this.
  10. tracy ing
    384
    167
    wash dc
    So, this is kind of cool...
    Supposedly, as I make changes, while I am conditioning these, the data in this link which is a pdf will auto update. So you can follow along lol.
    docs.google.com/spreadsheets/d/e/2PACX-1vSx-WW7K8mTj9YxoQQauVHKokyvHNWENl7WH8VD_i-Z5Fano87mN5itP7M-acQUpMnqNuMlrNzj9sS7/pub?output=pdf
    when i paste it in my browser it works without the required part I stripped off the front, if i leave that on their it gets wacked out by the forum software, you know the ache tee tee pee stuff
  11. tracy ing
    384
    167
    wash dc
    This is the first 8 odd numbered batteries on the 4th cycle (starting at 3 not 1)
    Meg&Bear and JohnPrius3005 like this.
  12. tracy ing
    384
    167
    wash dc
    In the end, only cell 2 is bad, and it is real bad, all the others came up nicely and once i replace cell 2 they will be ready to be placed in their new pack.
    When I get them ready to go, I discharge at 6.5 amps to 6 volts, then charge right up at 6.5 amps for 10 minutes and note the voltage
    I will use that to PAIR the cells up into banks so there is no aberrant behavior between banks and no codes.
    Another method I have used to pair them was capacity testing, and I would use excel and pair the best module with the worst, then the 2nd best with the 2nd worst, etc etc. and that worked so far over 130k miles on my 2005. IMG_20220623_075624.jpg
    #12 tracy ing, Jun 23, 2022
  13. tracy ing
    384
    167
    wash dc
    I discharged each already discharged module to 6.5 volts at 1/2 C 3.2 amp load.
    Then I charged them based on time, 15 minutes, at 1C 6.5 amps.
    27 of the 28 cells are in serial number order from the same 2008 car are factory original unknown mileage,one of the cells, number 2, replaced one of the bad original modules, it is a 2004 with about 150k miles on it.
  14. tracy ing
    384
    167
    wash dc
    the csv file for the aforementioned 15 minute chargeup
    JohnPrius3005 likes this.
  15. PriusCamper
    11,055
    4,499
    This is really nice discharge data! And you get this as output from your "West Mountain CBA II" discharger direct into your computer?
    Can you tell us more about this device with links and photos? Having a chart like this would make evaluating modules so much more efficient and accurate. How much would it cost to get set up with this?
  16. alftoy
    alftoy Senior Member
    1,132
    509
    Saskatchewan, Canada
    I think Tracy has stopped posting. West Mountain CBA V is $189.95
    Re-hydrating the battery modules. | Page 21 | PriusChat
    West Mountain Radio - Computerized Battery Analyzer
    Backordered CBA V - West Mountain Radio - CBA V - Computerized Battery Analyzer
    West Mountain Radio - Detailed CBA Comparison Chart
    #16 alftoy, Jun 24, 2022
    PriusCamper likes this.
  17. tracy ing
    384
    167
    wash dc
    Just test drove the new pack....
    Went over the mountain and just prior had to pass a car from 30 mph to 75 mph.
    Here's what the battery looks like now
    Passing the car then slamming on brakes to turn right to go over mountain
    Now Going Down the Mountain - Regen
    And now cruising straight and level
  18. JohnPrius3005
    JohnPrius3005 Active Member
    414
    224
    California and Hawaii
    Tracy, this is a great data and science based approach to reconditioning these cells. Awesome!
  19. tracy ing
    384
    167
    wash dc
    Follow along, these are the cells pulled from the 2008, they are 2012 dealer installed replacements.
    docs.google.com/spreadsheets/d/e/2PACX-1vSx-WW7K8mTj9YxoQQauVHKokyvHNWENl7WH8VD_i-Z5Fano87mN5itP7M-acQUpMnqNuMlrNzj9sS7/pubhtml
  20. tracy ing
    384
    167
    wash dc
    docs.google.com/spreadsheets/d/e/2PACX-1vSTiKNgzc7gyAROwq3FCgvNarkLEqL4nj4v6EDuwEUcnmeNmPZr5uU98X95s5qLIdw-Fgn1St1NUmIH/pubhtml
    docs.google.com/spreadsheets/d/e/2PACX-1vS2nXlg9ijcSNTZxMIuagRbj3nPCNDpNs_rTgmnMjgJO-CXgPjm16PA07j7Tyt4JJtVpAFQyiti8NWt/pubhtml
