Featured how is 131MPGe actually calculated?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by CINQUIRY, Feb 18, 2021.
  1. CINQUIRY
    CINQUIRY Junior Member
    Little Rhody
    2020 Prius Prime
    after 6 months of owning a Prius prime 2020, I am still confused on the how this calculated. Combined with electricity from the hybrid system, the government estimates it will earn 133 MPGe. I assume this is for just a 200 mile trip and one would need to recharge battery to obtain the 133MPGe to continue this number. Here is the article I read: - "" the Primes tested on our 200-mile fuel-economy route missed their EPA highway rating. However, since we test at a considerably higher speed (75 mph) than the EPA, we'd be impressed by any plug-in that was able to equal its EPA number. In hybrid mode, the Prime Plus earned 47 mpg highway and the Premium model earned 49 mpg. We also tested each in EV mode where the Plus earned 116 MPGe and the Premium earned 118.
    does anybody have any other real data.
  2. Rmay635703
    Rmay635703 Senior Member
    2,590
    1,608
    Somewhere in Wisconsin
    2013 Chevy Volt
    No voodoo here
    A gallon of gasoline has 33.7 kwhrs of energy
    This allows you compare electronical consumption to mpg in common units 3A2BB6BF-8BCD-4512-9FF4-D9C9715D609A.png
    jerrymildred likes this.
  3. fuzzy1
    10,138
    That 133 MPGe rating is for strictly plug-in use, not using any electricity generated from the hybrid system. And it isn't for a 200 mile trip, none of the test cycles are that long, nor is the battery range that long.
    Here are some EPA links:
    How Vehicles Are Tested
    Detailed Test Information
    https://www.fueleconomy.gov/feg/pdfs/EPA%20test%20procedure%20for%20EVs-PHEVs-11-14-2017.pdf
    Of the 5 drive test cycles rolled into the ratings, one does briefly get to 80 mph, but still averages just 48 mph, well short of your 75 mph trips. And that cycle has a total distance of just 8 miles. The longest test cycles are 11 miles.
    #3 fuzzy1, Feb 18, 2021
  4. Lee Jay
    Lee Jay Senior Member
    5,850
    4,023
    Westminster, Colorado
    My long term average is 5 miles/kWh. 5 miles/kWh × 33.7kWh/gallon = 168.5mpge. That's on electricity.
    When on gas I usually get between 56 and 72mpg. I really only use gas on road trips out of town.
  5. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    Both of those stats match mine exactly.
    I REALLY wish the EPA would just have used miles/kWh. It's so much more direct and it's what the car records. Why make some artificial number just so you can confuse people using a term that include "mpg?" Anyone not knowing the obtuse formula the government invented to produce it, naturally assumes that it has to do with gasoline. It has nothing to do with gasoline.
    Useful numbers on the Monroney sticker would be cost per mile in EV mode at $0.XX per kWh. Like they do with refrigerators. Or just miles/kWh.
    hill, fuzzy1, John321 and 1 other person like this.
  6. john1701a
    john1701a Prius Guru
    12,749
    5,244
    57
    They did use a ENERGY/DISTANCE measure unit. People don't focus on it though. They obsess with MPG, which never made any sense... and is the reason why most of the rest of the world does not. MPG encourages deception. Its misleading nature has been exploited for decades... even by hybrids. Remember Two-Mode?
    A big part of the problem is that it originates from people not being aware of the rating's purpose. It is to provide a standardized measure to enabled a means of comparison within a class of vehicle. Comparing to a mismatch distorts reality, feeding a narrative. Sadly, it's one that calculation itself only serves to mystify. Most people don't get it... hence "e" for equivalent.
    In other words, the new MPGe is just as misleading. So, stop using it. The other value on the window-sticker is the ENERGY/DISTANCE rating. It informs you how many kWh of energy is required to travel 100 miles of distance. For a dose of reality, think about what that actually means. It's the reverse of what everyone here has been taught all their lives. Instead of more being better, you want less.
    For example, the rating from Prius Prime is "25 kWh / 100 miles". Despite it being a hatchback and the other Prime model being a large SUV with AWD, the rating for RAV4 makes its efficiency difference obvious: "36 kWh / 100 miles". There's no other detail necessary. With that value, you know precisely how much more energy it takes to travel the same distance with the less efficient vehicle. Try that with MPG.
    Absence of simplicity is why the deception has persisted. People with power fought to keep the status quo from changing, even with the switch to electricity.
  7. Trollbait
    11,494
    It is because the focus groups they had preferred the MPGe over anything using a form of watt hours.
    Really, any distance per unit of fuel is worse than amount of fuel per distance. The latter is easier for most to grasp, people think of trips in terms of distance, and it is easier calculating averages with.
  8. CINQUIRY
    Little Rhody
    2020 Prius Prime
  9. CINQUIRY
    Little Rhody
    2020 Prius Prime
    If the rating from Prius Prime is "25 kWh / 100 miles". What is the math for cost of charging. The local rate is .22kWh.
    Is it as simple as 25 x .22 to figure cost to drive the 100 miles.
    Gas is $2.50 gallon. Need to know who’s much to charge prime 2020 at home.
  10. Lee Jay
    5,850
    4,023
    Yes. However, 4 miles / kWh (the same as 25kWh/100 miles) is just an estimate. My long-term (nearly 4 years) average is 5 miles / kWh. Yours may be different.
    The cost of ownership has very little to do with the energy use on this car. It's so efficient that the energy use is practically nothing. TCO is dominated by initial cost, insurance and maintenance, and maintenance is dominated by tires.
  11. dbstoo
    dbstoo Senior Member
    1,320
    698
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    The 25 kWh / 100 miles is energy needed to recharge the battery after 100 miles of driving. That should include the loses from charging / discharging. So the answer is yes, "Is it as simple as 25 x .22 to figure cost to drive the 100 miles."
    Dan
