How level is needed for transmission fluid change?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Bevicor, Jun 20, 2024.
  1. Bevicor
    Bevicor New Member
    Michigan
    2015 Prius c
    I'm looking to do the transmission fluid on my 2015 Prius C. With the current setup I have, using a level, the bubble is inside the two lines but just touching one (see pic). Is that good enough? How precise do I have to be?
  2. Leadfoot J. McCoalroller
    7,131
    6,679
    Pennsylvania
    2018 Prius c
    That's close enough, you're set.
    Open the fill port before opening the drain- just to make certain you can refill it.
  3. Mendel Leisk
    38,634
    Yeah just think about it. I don’t have Prius c repair manual instruction, but for various others the spec is for the fluid to be anywhere between flush with fill hole lip, to 10 mm lower.
    what’s never stipulated, is that it’s maybe a good idea to have the car level. All I can think is Toyota’s repair manual writers/editors never pictured anyone other than dealership mechanics with a full lift system doing a transaxle fluid change. But common sense leads DIY’rs to: you want to do that level check with the car “roughly” level.
    there’s some info in my signature on transaxle fluid change. It’s specific to 3rd Gen Prius, but still worth a read. (On a phone turn it landscape to see signatures)
    #3 Mendel Leisk, Jun 21, 2024
