How long are Gen IIs lasting?
Discussion in 'Gen 2 Prius Main Forum' started by mattmonsour, Mar 26, 2018.
  1. mattmonsour
    mattmonsour Junior Member
    51
    Hello!
    Been awhile since I've posted on here. My Gen II Prius is now 13 years old and has 237,000 miles.
    I'm just curious, generally speaking how long are Gen II Priuses lasting? I'm not talking about the battery (I replaced that back around 178,000). I'm talking about all the other stuff. (Obviously no one can predict for any particular car, I get that, I'm just asking about generalities.)
    I see the sticky post about 300,000+ and the like. I'm curious how out of the ordinary that kind of mileage is.
    Also, I'm long past the suggested maintenance in the manual. Anything I should be getting done on the maintenance front out of the ordinary? Anything I should be having checked for wear?
    This was brought on by the need to buy new tires. Normally I buy the longest lasting tire they offer. I started wondering, at this age, if that's worth it:) I'm also looking at the financial aspect of preparing for the next Prius.
    Thanks for any insights on how long Gen II Priuses tend to keep going!
    Matt
    PS, I did some googling about this before posting but it just turns up lots of stuff about the batteries:-(
  2. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My 2004 was still running fine at 288k miles and 12 years (with a rebuilt HV battery at 195k miles) when I traded it in for my 2016 Prius 3
    JeffD
    Don Shouse likes this.
  3. philipc
    philipc Junior Member
    38
    toronto
    I honestly have no idea but am in the exact same position you are. My 06 hit 200,000km last week, needs new all season tires and is still on the original battery so i'm confident i'm on borrowed time with it. Looking at either trading it in for something newer or just accept the replacements needed "soon".
  4. jm98
    jm98 Member
    155
    37
    17
    Four Touring
    I have 2006 still running 240K but ABS Actuator will likely to end my ownership. I say ABS Actuator will kill many Prii in market unless there is a cheaper solution available soon.
  5. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    The old family prius has 310k miles and still has original struts, and replaced battery at 240k miles. The old battery nenver even failed, I replaced it with a newer 07 battery for fun. Amazing car! Everything works
    jm98 likes this.
  6. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    My son has my 2004. It has about 280,000 miles on it and still runs great. A/C quite though and he didn't get it fixed.
    Aaron Vitolins and paprius4030 like this.
  7. bisco
    51,141
    generally 10-15 years, and 150-200,000 miles.
  8. chelvis
    chelvis Member
    84
    49
    Long Valley, NJ
    My 2005 has 283K on it, original HV battery. It is my daily driver. This thing is a Timex watch (wow OLD reference). I am debating whether to get a new HV battery or get a whole other lower mileage Gen 2 Prius.
    pilotgrrl and Aaron Vitolins like this.
  9. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    The main killers of the cars is usually the hybrid batteries. What seems to be true on the forums is battery failures start around 12 years and pretty much all batteries are dead after 18. This is why you see almost no first gens around anymore, only the occasional 03. So likely we'll see gen 2s on the road until the late 2020s.
  10. strawbrad
    953
    1,002
    My fleet of 04 to 08 have 148K, 228K, 293K, 303K, 331K, 375K.
    These cars will last as long as someone takes care of them. The engines get pretty worn out at 400 to 500K. +1 on the brake actuator repair. That's going to be an expensive repair that will send may to the junk yard. Accidents take their toll also. Batteries don't have to be that expensive to keep going.
    Brad
    pilotgrrl and jerrymildred like this.
  11. wjtracy
    wjtracy Senior Member
    11,360
    3,606
    Northern VA (NoVA)
    Geez even 3 of 4 of my TPMS are still good approaching 12 years.
    Just came over the mountains to Pittsburgh, and it is duck soup for the battery in winter with heat on inside the car.
    Summer more challenging with A/C on, then I get worried about the batt performance when it drops into the purple up a big mountainside. But I think in the cooler winter climates we get a good 6 months easy life for the battery.
  12. bisco
    51,141
    there aren't any statistics, so it's hard to say. certainly, we have examples of 2,3,4,500,000 miles, but we also have examples of 10-12 years old with a needed $2-3,000. repair that sends the owner packing.
    most anything will last as long as you want to keep pouring money into it.
  13. franken1313
    franken1313 Member
    216
    26
    US
    Mines a 2005 120k miles and it's dead, P Lock problem..
  14. bisco
    51,141
    that's the problem determining life span.
  15. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
    @strawbrad Hi Brad, also in Minnesota. You have 6 Prii? What do you think of the gen 3 Prius? Is it as robust as the second gen model in terms of longevity?
    Why do you think the engine gets worn out at 400-500k? I would think that the hybrid system allows for longer use of the gas motor.
  16. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    I was just noticing today that the Gen 2s here in Tennessee are starting to look rough. Dented, faded, scratched ect. It makes me sad honestly. These were such high tech nice cars when they were new. I guess its hard to believe the gen 2 has been on the road for over 14 years now.
    strawbrad likes this.
  17. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    The more miles you put on them, the longer they seem to last. Assuming of course, basic maintenance is provided and anything that requires attention gets it.
    HV batteries HATE sitting unused.
    Aaron Vitolins and srellim234 like this.
