How long can C-Biscuit sit without being driven?
Discussion in 'Prius c Main Forum' started by rosethornil, Nov 16, 2022.
  1. rosethornil
    rosethornil Member
    47
    30
    Virginia
    2016 Prius c
    Due to personal reasons, my 2016 Prius C is sitting in a garage and has been for six weeks. I filled the tank up before I parked it in the garage.
    The car has 106,000 miles and is in excellent shape. Yes, the gasoline in Illinois is 10% ethanol. I’m just wondering how often I need to pull it out of the garage and have someone drive it.
    I am wondering if our gas-sipping Cs are more sensitive to aging gasoline than most cars.
    Thanks for your help!!
    49,371
    you might want to squirt some gas saver in the tank and drive it once a week.
    the 12v should have a smart charger, or disconnect the neg terminal.
    watch the bars on the hybrid battery, i would drive it enough to keep them at 4 or more
  3. Leadfoot J. McCoalroller
    7,133
    6,682
    Pennsylvania
    2018 Prius c
    No special sensitivity to fuel.
    I think bisco is referring to fuel stabilizer, to prevent chemical breakdown. A 2oz bottle sta-bil is a fine investment.
    I'd say once a month is fine for exercise.
  4. Kerrynzl
    Kerrynzl Junior Member
    New Zealand
    2016 Aqua
    You're over thinking it.
    The "C" engine is basically multi-fuel Atkinson cycle [High compression ratio but the cylinder pressure is bled-off by cam timing]
    The O2 sensors and air flow meters will correct this.
    I have a Ferrari that was last gassed up in February 2022 and sits on a battery tender. When I started it, I could smell the Ethanol initially then it goes away. [So I don't give a sh**]
    Ethanol will not evaporate in the fuel lines and fuel tank which is a sealed system, and any fuel returning to the tank mixes it back up.
    It is more off a problem on carburetor engines.
  5. rosethornil
    rosethornil Member
    47
    30
    Virginia
    2016 Prius c
    Very helpful!!
    Thank you so much!!
  6. PriusII&C
    PriusII&C Active Member
    370
    129
    San Jose, California
    I have parked my 2012 Prius-C in my garage since May 2000. During the past 2.5 years, I started (not drived) it only every 2 - 4 months to charge the traction battery, and never see battery level bar move before charging it.
    I also add fuel-stabilizer to the fuel tank. Last December I sipped out the fuel from my Prius-C and put it into my Prius. My Prius performed normally with the 19 months old gasoline.
    The auxiliary battery needs more care. I disconnected it from the car and charged it once per month.
    I also partially lifted the car on 4 jack stands to prevent tire flatting.
  7. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    I have left my C parked for 6 weeks without doing any special treatment. Just hopped back into it and turned it on.
