How long can I run on gas
Discussion in 'Gen 3 Prius Main Forum' started by 2012prius1, Feb 9, 2018.
  1. 2012prius1
    2012prius1 New Member
    Honolulu
    hybrid battery needs to be changed
    But the motor runs and the car can be driven
    How long can I just run on gas?
    Thx
  2. FuelMiser
    FuelMiser Senior Member
    1,299
    887
    Monument, CO
    Personally, if there are no warning lights and the traction battery charges/discharges as expected, you can continue to drive it. I would not drive it if there are steady warning lights and/or the traction battery is not charging/discharging when in operation.
  3. Mendel Leisk
    38,709
    How many miles?
    What symptoms/warning lights do you have?
    Have you had it into a dealership for code check, diagnosis, proposed strategy?
  4. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    The Prius needs a semi-healthy traction battery even when "driven on gas". It starts the engine, for example. It also operates the "transmission". You can't separate the electric part of the hybrid drive train though many try to in their minds.
    The answer to your question is "as long as it keeps operating". Not very satisfying I know, but the truth. If the battery has been checked and bad cells were discovered, probably not very long. They get worse fast.
    Prodigyplace likes this.
  5. bisco
    49,446
    until you run out of gas...
    Danny3xd, Prodigyplace and Grit like this.
  6. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    If you drive it down hills, never run out of it.
  7. tvpierce
    tvpierce Senior Member
    949
    879
    Maine
    2013 Prius v wagon
    What leads you to believe the hybrid battery needs to be charged?
  8. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    They said changed Still a good question.
  9. tvpierce
    949
    879
    Maine
    2013 Prius v wagon
    Oops!
  10. Keepdriving
    Keepdriving Junior Member
    35
    27
    Palatine
    I've been driving mine for over 14K miles since the first Check Your Hybrid System light came on about 9, 10 months ago. Since then had the light come on about 6 or 7 times more as I was careless in watching where the battery level was. So far so good. Took it for a 1000 mile trip a couple of times and seemed to have recharged the battery a bit.
    Not that I'm recommending that you do this but my prius has 206K so didn't want to put in $3600 the dealer wanted for a new battery.
    Danny3xd likes this.
  11. Prodigyplace
    11,696
    11,318
    Central Virginia
    If you are on the Continental US and a DIY type you could get @2k1Toaster ’s kit of new cells for $1600 delivered with a 2 year warranty. Details in my signature.
  12. Keepdriving
    35
    27
    Palatine
    I'm in Illinois. The car is squeaking and getting old. I'll have to think about spending $1600. I just have to drive in certain way and so far seems good. Thanks though.
