How Long Can The Prius Sit Without Being Run?
Discussion in 'Gen 2 Prius Main Forum' started by Sid, Jul 8, 2005.
  1. Sid
    Sid New Member
    284
    Pennsylvania
    How long can the Prius sit without being turned on without any adverse affect on the Hybrid battery, or starting up again?
    Is one week OK?
    Should I still deacivate the Smart Key sensor?
    TIA :?
  2. helmkera
    helmkera Junior Member
    52
    Sandwich, Illinois
    2025 Prius
    XLE AWD-e
    I am a new Prius owner (less than 2 weeks) and took delivery of my new baby just three days before leaving (via airplane) for a 10 day vacation. The Prius was fine when I returned. Perhaps not a technical answer - just practical experience.
  3. Sid
    Sid New Member
    284
    Pennsylvania
    Thanks for the info helmkera, that's one less thing to worry about when that time comes.
  4. dspguy
    dspguy Junior Member
    49
    Boston
    My personal experience is < 3days if you have a 7 year old son who leaves on the rear dome light and nobody notices.
  5. DaveG
    DaveG Member
    806
    Vancouver, BC
    <div class='quotetop'>QUOTE(Sid\";p=\"105454)</div>
    Most people seem to feel that if you're going to leave the car for more than a week or two, you should disable the smart key sensor to reduce the current drain on the small 12v battery.
    Other than that, if you're planning a longer-term, the car should be started for a few minutes every couple of months to preserve the high-voltage battery.
    Dave
  6. prius04
    prius04 New Member
    1,161
    NorthEast USA
    Actually, the answer to this is in the manual. I'm pretty sure the "cut off" is 3 weeks, but there was a Priuschat post many many months ago where a guy went 5 weeks with zero problems. But whether this 5 weeks would affect the long term viability of the battery is, of course, unknown.
    And there is a way to shut off the SKS, and this should help some. There is a small button under the dash near the base of the steering wheel stalk and dash. This will shut off the SKS and save some electricity. This is also described in the manual.
    But I would not be inclined to go above 4 weeks without someone starting the car for a few minutes. I love the car too much.
  7. Tideland Prius
    16,611
    make sure everything's off. SKS, headlights, all switches turned to OFF position (vanity, trunk, dome). I guess, anything that could trickle the battery. Also keep the fob away from the car
  8. funpilot
    funpilot Junior Member
    73
    I have gone two weeks on several occasions without any problems. Also, left a door slightly ajar for a week and had to jump start it....again no problems.
