How long do you expect your HV battery to last?
Discussion in 'Gen 2 Prius Main Forum' started by uart, Apr 23, 2012.
  1. I think I'll be lucky to get 100,000 miles
    3 vote(s)
    3.4%
  2. 100 to 150 k-miles
    11 vote(s)
    12.4%
  3. 150 to 200 k-miles
    26 vote(s)
    29.2%
  4. 200 to 250 k-miles
    24 vote(s)
    27.0%
  5. More than 250 k-miles
    25 vote(s)
    28.1%
  1. uart
    uart Senior Member
    4,220
    1,211
    Australia
    If you keep your Gen2 Prius long enough, then given your particular driving conditions, how long would you honestly expect the hybrid battery to last?
  2. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Good to see some optimistic votes. :)
    I only selected 150 to 200 k-miles.
  3. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    My friend who was an early adopter and got his 2004 in late 2003 as one of the first delivered here in the NE still has it with over 225,000 miles on it. No reason these batteries should not last 250k+. Taxis have already shown it is quite do-able.
  4. justlurkin
    justlurkin Señor Member
    499
    63
    Long Island, NY
    I do pay attention to SOC on long downhill descents and use B-mode to prevent overcharging the battery, and leaving the car parked with windows slightly cracked open on hot summer days so the temperatures in the cabin doesn't build up to ungodly levels as the car sits in the sun.
    Figure these things will keep my '07 Prius HV battery happy and healthy past 150,000 miles.
  5. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yep, but unfortunately were I live there's lots of hills and plenty of heat. I think the traction battery will wear out faster under these conditions. So far it's only done 92000 miles (had done 41000 miles when I bought it S/H) and already I think I can notice the battery is slightly weaker than when I first got it (at 41k). Having said that though, the battery is still in pretty good shape. I honestly don't expect it to die real soon or anything. But I wont be surprised if I see a gradual decline in battery capacity/performance over say the next 100k miles, and with this a somewhat increasing probability of outright failure.
  6. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I hear you but I still think you're good for 200k plus, and very possibly good for 250k plus if you choose to keep your car that long.
  7. sarahc
    sarahc New Member
    I've got 198,000 miles on my 2005 so far. We went to the dealer to check out new priuses, and was told we could expect at least another 50,000 to 100,000! I will keep my fingers crossed!
    68charger440 likes this.
  8. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    1) I do not think it depends on the number of miles but on number of summers, so being a long distance driver means I will get more miles in fewer summers.
    2) The more your Prius is in use, the more time the computers are coddling your battery, so never taking any days off driving means my battery is coddled every day.
    3) I know it has lasted 93,000 miles already, so there is no point in guessing under 100,000
  9. kevin3
    kevin3 Junior Member
    25
    Sacramento, california
    200K already on original HV battery. I am hoping for 250K+ but would still be hapy with between 200-250K since I can get a replacement installed for about $1200
  10. sciencekit
    sciencekit Junior Member
    76
    Norfolk, VA
    The traction battery in my 2004 died at 147k miles. I traded it in for a reconditioned unit from Re-involt. Did the work myself (it's quite easy) to save some cash. Though I was pissed it failed so early. I was accustomed to my 4-Runner, whose only major repair was a clutch replacement after it hit the a bit over the 200k mile mark... and that was only $300 to replace clutch, flywheel, etc with a TRD kit.
  11. lamebums
    lamebums Member
    101
    30
    Southern Ohio
    Hi all--
    I use the ScanGauge's SoC meter and make a conscious effort to keep the SoC as consistent as possible - generally right around 60%, or 6 bars if you don't have a ScanGauge. I almost never let the battery drop down to 5 or even 4 bars. I think cycling the battery as deeply as possible is what wears it down.
    I've got a friend with a 2004 at 210k and he drives his like crap. And the battery is still going strong.
    I'd hope I can get 250 or more out of mine. At about 25k miles/year, that will take me about another eight years.
  12. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yeah that sounds like a good plan, your battery should last forever. :)
    I also try to keep my SOC fairly consistent, but I still get a lot of hills were I just cant avoid large SOC swings. One change I have made to my driving habits is to add a very small warm up (often just 30 to 40 seconds in "P") and it really helps keep my SOC more consistent at the start of a trip. Previously I used to find that the SOC would drop to 2 or 3 bars in the first few minutes when the engine was cold. Now it rarely drops below 5 at this time.
    I have to confess however that sometimes I just cant resist gliding a bit too long in EV mode, and sometimes I run it down to 3 or 4 bars. But I'm trying to resist the temptation. :p
  13. bisco
    52,383
    our 04 with 95,000 is up for sale. it runs like brand new and still gets 55-65 mpg. it has had gentle driving, a reasonable climate, garaged parking and not much in the way of big hills. barring any defects, i think 2-300,000 miles is not out of the question.
  14. manolommad
    manolommad New Member
    Coppell Tx
    Mine lasted 270K miles before replacing.
  15. Fritzi56
    Fritzi56 New Member
    Rockton, IL
    Mine died at 148000. No reason given; sometimes they just go bad. $4275.00. Originally to take a week to get the new battery from the west coast. Now the end of May at the soonest.
  16. lamebums
    lamebums Member
    101
    30
    Southern Ohio
    Hi frizi56--
    It may be a little late to change your mind especially if the money's already been charged, but with 148k miles you could consider a salvage battery? I'd just think you stand a good chance of a brand-new HV battery significantly outlasting the rest of the vehicle and I'd hate to think you'd plunked down enough for a decent used vehicle on just a battery. Since you're in the Midwest, I'd suggest this guy. About 3/4 of the way down, you can get a salvage battery for $995..
    Edit: I should clarify he's in Indiana - depending on where you are in Illinois it may be worth a shot taking a drive rather than waiting weeks for a new battery.
  17. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  18. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    If PriusChat member JDenenberg could not get to 200,000 with his first battery, I do not think I can either. By the time I get to 200,000 my 2006 would be 10-yrs old and I'd bet dollars to donuts there is some corrosion on the terminals and other parts.
  19. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    First of all, corrosion has NOT been a serious problem in Gen2 or later Prius batteries. You live in a cool climate and the odds are that you will get 200k or more out of your HV battery. 27 of my 28 modules were still in good shape at 195k miles and 8 years of use. One Module suffered enough imbalance that caused a cell reversal when the Battery was discharged to 40% SOC which was just one point on the probability curve for these batteries.
    JeffD
  20. thesaint
    thesaint Junior Member
    28
    norton, Massachusetts
    I
    kevin,
    what type of mechanic can fix your battery pack for $1,200?
