How long does it take to warm up?
Discussion in 'Gen 3 Prius Main Forum' started by Higgins909, Jul 27, 2019.
  1. Higgins909
    Higgins909 Member
    277
    67
    2010 174.5k~ Level 3 trim. How long it is supposed to take for it to warm up? It seems like when it "warms up" It gets better mpg and easier to coast and accelerate. However, this is often towards to end of my 20 minute drive. Doesn't seem to matter if it's summer or winter.
    51,154
    not that long. of course it depends on ambient air, but 5 minutes at the most i would say.
    you know when the engine shuts down and you can coast with it off, or it is off when you stop
    Bay Stater likes this.
  3. Mendel Leisk
    40,583
    I think engine will shut off before it's completely warmed up? It'll shut off just at a full stop, say at red light, and as long as cabin heat requests are low. I'd call that partially warmed up; it still won't shut down if you lift off the throttle while moving. Bottom line, there's multiple stages of warmed up.
    We confuse ours too, with the block heater methinks.
    fuzzy1 and Bay Stater like this.
  4. Lovec1990
    Lovec1990 Junior Member
    74
    Slovenia(EU)
    i know im not helping, but gen 4 based on video bellow starts fully using electric motor after driving 0.7miles at 63°F outside temp, but said car was parked in garage with 72°F room temperature.
    Gen 3 should take longer, but i agree with @bisco up to 5min should be normal time in witch car should be able too use hybrid system fully
    Video:
  5. fuzzy1
    10,335
    Mendel Leisk and ice9 like this.
  6. Tideland Prius
    16,445
    About 6-10 miles of city driving (shorter if you’re on the highway since it’s always on). Longer if it’s the winter.
    Yes, once it’s up to operating temperature, the mpg will rise. That’s why those of us trying to minimise the winter mpg hit will use an engine block heater to pre-heat the engine (electricity use is more efficient than gasoline to heat up the block when it’s cold outside), then block the lower grille/air dam (don’t block the upper grille) to reduce the cooling effect as you drive.
    Bay Stater and Mendel Leisk like this.
  7. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Usually about 5 minutes to warm up. A bit longer during the Winter months. You will know when the car can cruise on the traction battery.
    bisco, Raytheeagle and Mendel Leisk like this.
  8. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    You all are fake news!!!
    I just drove 15 minutes no farther than 10 miles, all under 35mph. ICE was only 168F after the drive with bottom grill fully blocked, ambient temp was 79F 8am.
  9. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    Can a gen 1 member please post their warm up time also, it would soooo help us gen 3s
    #9 Grit, Jul 28, 2019
    Lovec1990 likes this.
  10. Tideland Prius
    16,445
    Yeah maybe actually helping out and finding that thread would be more productive to this thread?
    @Higgins909 , here's the Gen 3 warm up stages. It doesn't tell you how long it'll take but it'll tell you when you're in the different stages so that you can experiment with your commute/drive.
    Gen3 warming up stages | PriusChat
    Bay Stater and fuzzy1 like this.
  11. fuzzy1
    10,335
    Don't the internal computers consider that as being fully warmed up? My other car (a Subaru) turns its cold-engine light off at about 140F. Its predecessor, with a needle temperature gauge, collapsed the whole temperature range of about 145-210F to a single gauge point as part of its 'customer expectation management'.
    Sure, it is not up to the thermostat setting that it reaches in standard flat highway speed conditions. But low speed city / suburban streets with plenty of ICE-auto-off time might never get higher than that.
  12. bisco
    51,154
    final stage is only 70c, or 158f according to ken in tide's link above.
    and if the engine is as low as 60c, 140f, when you power up, it is already in the final stage
  13. Mendel Leisk
    40,583
    #13 Mendel Leisk, Jul 28, 2019
    Bay Stater, fuzzy1 and Grit like this.
  14. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    That's a great guide. I wish he specify if it's warm up on driving city limits, stop and go, or heavy highway traffic to go along with the guide.
  15. Mendel Leisk
    40,583
    Steady highway speeds warm it up best I would guess. And/or sustained up-hill climbs. If you're going up any mountains I would take all grill block out for sure, any time of year.
  16. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    I was being a pain on purpose because no one mentioned about elevation and long stretches of non-stop driving under 42 mph will affect warm up time also. That was this morning drive to the 1st grocery store, in fact its an descending hill that I begin on. I only pushed with ICE taking off from red lights and the rest was EV. Fully warmed up is 190 +, I came short of that temp even with the yesterday summer heat that stayed around.
  17. fuzzy1
    10,335
    I seem to remember it being an Arduino-based predecessor to, or alternative for, the ScanGauge.
    Not yet sure if it is an Arduino, but it is mentioned on a Wikipedia page: OBDuino - Wikipedia
    Also used on the modded AeroCivic: Inexpensive MPG Modding | Hackaday
  18. Tideland Prius
    16,445
  19. wheezyglider
    wheezyglider Active Member
    247
    178
    SF Bay Area
    One interesting thing about those old Prius warmup stage threads - EGR was not even on the radar back then. Sometime after S4, (up to several minutes in non-freeway driving) the catalytic converter gets hot enough to allow the use of EGR. I consider that "fully warmed up" with maximum fuel efficiency possible only at that point. Call it S5?
  20. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    In my opinion, 190F+ is fully warmed up :eek:
