How long does my hybrid system have left?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by utepri, Feb 12, 2025.
  1. utepri
    utepri New Member
    Utah
    2013 prius
    223,000 miles
    regular maintenece
    runs smooth
    12v battery replaced last year
    just looking for some advice on how long you think it has left?
  2. Brian1954
    Brian1954 Senior Member
    1,698
    663
    South Central PA, USA
    I would guess that the hybrid battery is nearing the end of its useful life. You could get a rough idea on the health of the battery by using the Dr Prius app to run the "Life Expectancy Test". The test is better described as a Battery Capacity Test. Search for the apps website.
    #2 Brian1954, Feb 12, 2025
    51,014
    i'd be more concerned with the head gasket
  4. Grit
    Grit Senior Member
    6,411
    4,181
    Wilkes Land
    2 years, 4 months, 1 day and 30 seconds left.
    fotomoto and MAX2 like this.
  5. Tombukt2
    Tombukt2 Senior Member
    11,994
    2,119
    Durham NC
    When you own a vehicle like this you should be having a spare or be ready at the drop of a hat and know what you'll be getting as a spare when this break so you can hem and haw over the nonsense or wifey has another car and she can get you to work or however you play the game I always have extra vehicles always even if they're never driven they're just sitting around they get started and moved around and taken to the store every so often so it's not like they're not used they're just not primaries or not until they become one I'm never out of a vehicle I don't want to have to run out and buy something because something broke I'd rather have an extra one here that I know and trust not one that I have to go out and find that's another project.
    vvillovv likes this.
  6. Mendel Leisk
    40,456
    How long have you had it?
    fotomoto likes this.
  7. Leadfoot J. McCoalroller
    7,824
    7,290
    Pennsylvania
    2018 Prius c
    For that model?
    Almost all of them last beyond 10 years
    Most of them make it past 12 years <-- you are here
    The oldest 3rd gen cars are turning 15 now. Lots of Toyotas were designed to last "about 15 years."
    Looking back to the 1st and 2nd generation cars, very few made it to 20 years, even with hybrid renewal.
    The third generation cars have problems (head gasket, brake booster) that earlier models didn't seem to have, so honestly I'd plan on squeezing it for another "two-ish years." Now is the time to be forming an exit plan- saving up for a replacement and minimizing any but essential spending on the current car.
  8. DirkAshburn
    DirkAshburn Member
    118
    47
    Virginia
    I have a 2011 and I'm just waiting for the hybrid to fail, been waiting years and it's still chugging along. Rest of the car runs perfect, I'll put the couple grand into a new battery. We do have our eyes on a new Rav4, but we're not in any rush. I could see this car lasting another 10 years.
  9. Mendel Leisk
    40,456
    What's the miles on it?
    Addendum: see you've done an EGR cleaning. (y)
    Grit likes this.
  10. bbrages
    bbrages Member
    162
    47
    St. Louis
    Time will tell.
    If you are a DIYer you may be able to keep it running through difficulties that would cause a non-DIYer to give up.
    If my 2010 head gasket finally gives up the goat, I'm planning on replacing it myself and continuing to rack up miles. Same with the hybrid battery. Dr. Prius has me at about 50%, which isn't great around town in the summer but is fine otherwise.
  11. Mendel Leisk
    40,456
    Something else to consider, when the head's off: if you've got heavy oil consumption, good time to either replace pistons/rings, or do a (new) short block swap. According to The Car Care Nut, they will all have the revised pistons/rings.
  12. Grit
    Grit Senior Member
    6,411
    4,181
    Wilkes Land
    Lithium battery?
  13. DirkAshburn
    DirkAshburn Member
    118
    47
    Virginia
    Well sodium-ion, but yeah maybe. I need to look into it more, been busy on other projects.
    #13 DirkAshburn, Feb 18, 2025
  14. ASRDogman
    ASRDogman Senior Member
    7,109
    3,713
    Sodium! It’s great!
  15. Grit
    Grit Senior Member
    6,411
    4,181
    Wilkes Land
    Ditto. The new battery would be useless if egr gets no cleaning.
    Tombukt2 and Mendel Leisk like this.
  16. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,497
    1,593
    Bay Area
    Mines a 2012 at 281k miles, I’ll let you know when mine goes out
