How long does the battery in key fob last (on average) for 2008?
Discussion in 'Gen 2 Prius Technical Discussion' started by howardbc, Oct 16, 2012.
  1. howardbc
    howardbc Member
    154
    Scottsdale, AZ
    Hi. I have a 2008 Prius with the Touring Package. It has 31k miles on it and I've had it 4.5+ years. (I'm retired.) I never actually ever use the key. I just leave it in my pocketbook 24/7 and run the car without it in the ignition slot. Also I don't use it to lock or unlock the doors. I just push the door handle button.
    Question: Can anyone tell me what the average life span of the battery might be? Also, is there any kind of warning when the battery is getting low? Yes, I read the Owner's Manual about the key fob but it didn't address any of my questions.
    Any feedback is appreciated. Thank you. :)
    49,435
    4 years is probably a good average. some go longer, some go much shorter. as it wears down, you will slowly find things not working. handle touch doesn't work but push button on fob does, etc. there is no telling how it will manifest itself, each case is a little different.
  3. howardbc
    howardbc Member
    154
    Scottsdale, AZ
    Thank you, Bisco! I better change it today!
    49,435
    probably a good idea. cheap peace of mind maintenance. and the sooner you change it, the less gummed up the fob is and the easier it comes apart. all the best!
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    Look at the fob while you push a button. There's a little red LED that lights up. That gets dim when battery starts going. Notice between now and and the new battery.
