How long does the ICE water pump's generally last?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by exmetrodriver, Jul 29, 2014.
  1. exmetrodriver
    exmetrodriver Member
    124
    16
    Puget sound, Wa.
    I'm at 132,000 miles and still on the original ICE water pump. Does anyone know when these typically expire? I'm not a "if it's not broke, don't fix it person". I did too many timing belts/water pumps on the side of the road when I was young from lack of preventive maintenance.
    52,789
    now would probably be a good time.(y)
    Mylar likes this.
  3. JC91006
    16,934
    8,644
    Check to see if there is any pinkish whitish build up on the pump. If you see some, then it's probably leaking already. If you don't see anything leaking then I wouldn't replace it. You should however replace the belt as that would need replacement from age.
    Meg&Bear likes this.
  4. Patrick Wong
    18,210
    6,517
    I agree that if you don't see any coolant seepage on the pump pulley interior or deposited upon the air conditioner compressor housing, then no worries. That pump will give you plenty of warning before it fails.
    I also agree that the serpentine drive belt should be replaced now if that had not previously been changed out.
  5. kammssss
    kammssss Member
    287
    86
    SoCal
    I believe mine lasted 150k. And I did see the pinkish stuff. Buy OEM for this part. I got an aftermarket, "like OEM," that only lasted 70k.
  6. alekska
    alekska Active Member
    435
    138
    Atl
    I agree on 150 k miles would be a likely life span of a pump. At all my previous cars ( Tercel, Legacy, Corolla) I had to do it around 150 k mark
    Alex
  7. FazilHussein
    FazilHussein Member
    71
    37
    Perth, Ontario, Canada
    Mine only lasted 100k km (60k miles); first suspected it when I had to periodically top up the coolant, and then it started making a racket. Grab the pulley and try to move it laterally....if there's play, replace it. $55 for the pump, $40 for replacement coolant from Toyota, hour wrench time, an hour bleed.
    Faz
    Meg&Bear and exmetrodriver like this.
  8. alexeft
    alexeft Member
    142
    24
    Greece
    I would leave it alone so long as the coolant level and the pump itself are checked regularly. As written above, it will give plenty of warning.
  9. exmetrodriver
    124
    16
    Puget sound, Wa.
    Thanks you all for all the good knowledge. I think I will order me a Aisin water pump ( ebay 49.00 shipped) just to have it. I have had my fill of cheap parts from the big parts stores. A lifetime warentee doesn't mater when you have to put another cheap part into a hard to get to spots. Stay away from parts from CHINA. I will inspect it today for leaks.
  10. JC91006
    16,934
    8,644
    You can get it on amazon for the same price, and it'll come with a proper receipt and warranty.
    exmetrodriver likes this.
  11. exmetrodriver
    124
    16
    Puget sound, Wa.
    If anyone is interested there is a youtube video from user dailydriven79 that makes it look somewhat easy.
  12. alexeft
    alexeft Member
    142
    24
    Greece
    If you decide (or have to) replace it, just don't put too much tension on the belt. Too much tension destroys the pump earlier. Besides, that belt has very little load on it.
    Meg&Bear and nh7o like this.
  13. exmetrodriver
    124
    16
    Puget sound, Wa.
    Good advice. Thanks!
  14. Priusyipee
    Priusyipee Active Member
    354
    269
    Upstate New York
    Changed mine last week on the 2005 at 209,000 miles - due to "weeping" (slight pink crusty deposits).
  15. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Pump and the radiator will last longer if you change the coolant at the minimum every year at least. Fluid if not changed tends to get acidic and aluminum salts which is very abrasive to the pump. A thorough change of the ICE coolant is painful though as coupled with the Thermos tends to airlock quite easily and hard to get the air out even with a vac unless you jump out power to the thermos and cycle it.
    Easiest way to maintain the coolant is very simple just dump the rad's content a couple of times a year. Use Toyota SLLC . You will not incur airlock and it does get quite a bit of the coolant out. Just take the cap off and open up the petcock and vent. Pour the used contents down the drain.
  16. priuspony
    priuspony Junior Member
    SE PA
    I installed my 3rd one yesterday, at 99k miles on our 2006. First one I replaced 3 ½ years ago, 66k miles. Replaced with Napa Truflow at that time. They honored the warranty, but I'm irritated that the part didn't last. I stay away from autozone and advanced auto - any parts with electronics or bearings. But I figured Napa would be quality. Not so I guess. I'm hoping this one lasts longer, but if not, I'll get OEM next time. I'm getting good at it though!
    Neither completely failed, but I saw the pink crusty around the bearing, and the weep hole was leaking. Probably could have run it longer, but that annoys me.
  17. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    May want to consider grouping your maintenance items purchase to get free shipping from Camelback Toyota in AZ; need to spend $150+ though.
    A genuine OEM replacement water pump was $54.42, no tax.
    ebay pump, $49, likely no tax. Amazon, $44.58 + $3.88 (tax 8.7%) = $48.49
    Small $5-$6 price difference, but you'll get a replacement quality part, that should give you lots of miles again, as you and many others have experienced.
  18. AzWxGuy
    AzWxGuy Weather Guy
    1,078
    558
    Tucson, AZ
    2021 Prius
    Sorry Ed, but I've been thinking about this last statement for a couple of days now. I finally decided to say something, not meaning to start any arguments hopefully. It would not be very environmentally friendly to dispose of used antifreeze in this manner. I am assuming that the "drain" would lead to a municipal sewage system. I'm not a tree-hugger or anything, but I do try to reduce my personal impact on an already overburdened natural environment.
    For the OP, I may have replaced my ICE coolant pump a little early, at 72K, based on some brief leakage. I figured all coolant pumps are created equal and once coolant has breached the internal seal it would wash out the grease in the bearing and lead to accelerated failure. From other threads on this subject it appears this sometimes isn't true. The pump will spit out some coolant from time to time without deleterious effects. The key I think is continuous and visible leakage. I didn't go with an OEM pump body either. Got one at Autozone. So far I have 110K on it without any further leakage.
  19. edthefox5
    10,096
    4,837
    Clearwater, Florida
    That's where your supposed to put it. Safest especially for animals. Its recycled.
  20. JC91006
    16,934
    8,644
