How Long Does The Key Remote Batter Last?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriusGirlyGirl, Nov 28, 2009.
  1. PriusGirlyGirl
    PriusGirlyGirl Junior Member
    37
    Washington DC
    I have a new 3rd gen. 2010 blizzard pearl prius. It's a beaute. But just finished reading the manual and was a little shocked to discover that if my key remote battery dies, I can't operate my car! So I decided to do some research and see where I can get a battery if I ever ran low and possibly buy a spare to save in my car, since they are relatively cheap, it's better than being locked out of my car!
    Do you know how long they last? I don't want to get one too early, so as not to have the spare expire before i use it.
  2. RodJo
    RodJo Member
    423
    56
    Boston
    I haven't pulled out my manual to find the page, but I believe you can still operate the car. You just have to use the mechanical key to lock/unlock the doors, and then hold the fob next to the start button to start it.
    xpcman, dogfriend and patsparks like this.
  3. patsparks
    10,664
    567
    Adelaide South Australia
    Rod is right
  4. djasonw
    djasonw Active Member
    950
    116
    Coconut Creek, FL
    In the GenII there is a slot to insert the key so even if the battery is dead, the vehicle will still start. I am not sure if the Gen III has the slot for FOB insertion.
  5. PriusGirlyGirl
    37
    Washington DC
    I think that is true for the most part. But the manual also says that it may not be able to start the engine on page 461. BUt I found the answer to my question in the manual on page 64 - says the battery life is 1-2 years.
    But I wanted to know what people were actually getting out of it, and if anyone had to take the precautions of the discharged battery.
  6. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    Find out what battery it uses and go buy one. The small batteries are more stable and have a much longer shelf life than the hi amp batteries, like the D, C, AA, AAA. Then tape it to the top of your glove box.
  7. john1701a
    john1701a Prius Guru
    12,754
    5,245
    57
    Mine lasted about 4.5 years, then I started getting a beep at shutdown to inform me the FOB power was beginning to weaken.
    This model looks easier to open and the battery is different (but it looks like a fairly common size and is listed online for $2.75).
  8. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    From page 541 of the 2010 Owner's Manual pdf:
    1.
    To enter the car when the electronic key is not working properly, pull the mechanical key out of its slot and use it to unlock the door.
    2. To operate the car when the electronic key is not working properly:
    (a) Apply the brakes and touch the Toyota emblem side of the
    electronic key to the “POWER” switch.
    (b) An alarm/buzzer will sound.
    (c) You then have 10 seconds to do what you normally do with the "POWER" button (switch to ACCESSORIES mode, switch to ON mode or start the car/put in READY mode). So,
    --- to change to ACCESSORIES or ON mode, within 10 seconds of the alarm/buzzer sounding, release the brake pedal and press the
    “POWER” switch once for ACCESSORIES or twice for ON.
    --- to start the car, within 10 seconds of the alarm/buzzer sounding, press the “POWER” switch while keeping the brake pedal depressed.
    The battery is a coin/disk battery - size CR1632. I think it's a common watch battery that's available online or any place where watch batteries are sold.You install it with the positive/+ side facing up.
    3 people like this.
  9. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    The battery typically lasts about 1 yr if used 10 times a day.
    However, since most people use it twice a day, it is typical to last about 4-5 yrs.
    Your "mileage", of course, may vary depending on how often you use it.
    Also, try to keep the fob away from the Prius (at least 20 ft) when not in use.
  10. jlim888
    jlim888 Member
    78
    36
    My 2011 Prius is 22 months old. The batteries (CR1632) measured 2.895v on Remote#1 and 2.896v on Remote#2. The fresh 3V batteries measured 3.3v. I think 2.895v or 2.896v is nearing the end of the useful life, so I went ahead and replaced them.
  11. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    The SKS key fob batteries lasted 2 years on my Camry.
    Just remember that you can start your car with a dead or low fob battery by holding the fob next to the Start button for a few seconds before pushing the Start button. ;)
    SCH-I535
  12. Cactuscoug
    Cactuscoug CactusCoug
    77
    Redmond, Oregon
    We have a 2010 with 53,000 miles. Earlier this month, the car would give us a warning: "Low key battery," upon start-up. We replaced the battery and everything is fine.
  13. Indy John
    Indy John Member
    75
    33
    Indianapolis
    My 2010 hatchback is 38 months old (since purchased) and a low fob battery warning appeared on my dash yesterday.
  14. jlim888
    jlim888 Member
    78
    36
    If you have a digital multimeter, could you please help to measure voltage of the used battery? Thanks.
  15. DavidA
    2,328
    1,812
    Chicago western burbs
    About four years. Both my GenIII fob batteries were low enough to cause the Low Key Battery alert. In fact it was four years to the day I picked up the car new. Batteries Plus had the lowest price $3.49 - about half of Radio Shack / Walmart prices. Very easy to change fob batteries yourself. Easily less than one minute per fob.
  16. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    One of mine started giving a low battery alarm after about 3 1/2 years, I used it for another 2 weeks or so and it never failed to work. The other never alarmed but I replaced both batteries anyway.
  17. GreenClipper
    GreenClipper Senior Member
    116
    Tulsa, Ok.
    I have a 2010 GenIII that will be 3yrs old the end of November. 90K miles, at the moment. We've had some key fob problems, but with both batteries having been replaced, all seemed to be working well till I recently had mine quit working regarding "proximity locking", or unlocking. Even had to pass the fob over the start button a time or two. Never failed to work when that was done. Well, now I've had problems with the fob not working despite having it in my pocket, from all outward thoughts it would be "battery", BUT, I have found that if I take the battery out of the fob, rub it off with a soft cloth & put it back in, all is well. So that tells me that there can be a failure due to the current that is available not passing through, (kind of like corrosion on the terminals of a regular car battery....?). The fob batteries do last an amazingly long time considering all that they have to do on this car. And there are plenty of warnings of something going wrong, so I personally wouldn't worry about carrying a "spare" battery with me. Just know what size you need, and where to obtain one, or two from when you need them. I bought two when my wife's one started acting up. Put the other one in a drawer in the house until mine started acting up, then installed it. Simplest job to do there is! Just try not to handle the battery with your bare hands, as that probably was the problem that caused me to have to take mine out & "polish" it. I bought mine at a local pharmacy where you had to buy a packet of two, to get one! Price was competitive from what was quoted here for one. No need to involve a dealer for the purchase of or the replacement of the fob batteries, EASY job!
  18. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    On two different occasions, a service technician has said that carrying a cell phone will decrease fob battery life. Has anyone else heard this?
  19. wjtracy
    wjtracy Senior Member
    11,321
    3,590
    Northern VA (NoVA)
    ...never heard the cell phone thing to my recollection over the last several years on Prius Chat.
    I see Gen3 went to different battery than Gen2 (2032), but Amazon tends to have cheap prices. I have found on other devices different battery brands seem to have wildly different life for the 2032. Either that or my other device is defective.
  20. PortlandBeerGeek
    PortlandBeerGeek Junior Member
    The exact same thing happened to me yesterday in my 2010 ii with 54,000 miles. Just replaced the battery (I had a backup battery in my glove box) after I got the message on the instrument panel, and everything is fine.
