How long does the Prius Plug-in warms up
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by syscon, May 5, 2012.
  1. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Does the Prius Plug-in warms up the engine in the morning before one can drive in electric mode?
    I have Prius 'v' (getting about 50MPG) so I'm curious.
  2. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    No. You can drive in EV mode until the charge reduces and forces HV mode.
  3. mitch672
    mitch672 Technology Geek
    1,077
    198
    Randolph, MA
    it doesn't automaticlly do anything. If you left the HVAC system in "auto', its very likely to start the engine, as its required for heat. If you didn't charge the car up, and it doesn't have enough energy to be in "EV" mode, the engine will start.
    If you punch the accelerator while driving in EV mode, the engne will start up.
    If you press the "EV/HV" button, the engine will start up (assuming it was in EV mode of course)
    If you drive faster than 62-63MPH, the engine will start up.
    so, no it doesn't start to "warm up" (which it does in about 1-2 minutes, depending on the ambient temperature), but there are many conditions the driver can do, which will cause the engine to start.
