How long have you had a clear bra on your Prii?
Discussion in 'Gen 2 Prius Main Forum' started by sunshine62704, Jul 27, 2008.
  1. sunshine62704
    sunshine62704 New Member
    22
    Illinois
    Considering clear bra for my new Prii, but want to know a few things first from those of you that have had a clear bra on for awhile now. Can you use bug and tar removal cleaners on it, and do scratches show up bad? How long have you had one on? Thanks for any info you care to share.:)
  2. captnpops
    captnpops Junior Member
    17
    Salt Lake City
    I've had mine on since new, April 05. A few things to consider:
    1st, While the paint will be ok, large rocks will still dent the hood. While the dents are the kind you can get 'popped' out, I haven't had mine done as I figured it would destroy or ruin the bra
    2nd, you can wax the bra, but I normally can get all bugs and tar off without using a tar/bug remover. Mine is a 3m product; each product could be different
    3rd, bra or no bra, the Prius front end is lower than most non-sports cars, gutters, driveways. Check out the height of the Prius next to a mid-size SUV(Toyoda Highlander)... the complete Prius hood is no higher than where the SUV hood starts as a normal SUV non-painted grill takes all the road grit.
    Finally, if you are going to get the bra, sooner is better... it will not hide any chip or blemish... just remember when it's done, you will be the only one finding those little things that you saw before..
    good luck
  3. sunshine62704
    22
    Illinois
    Thanks for reply Captnpops,
    Sounds like some good tips to think about. Have you noticed any yellowing of the bra? Some have made remarks that they collect moisture underneath, but I am of the inclination that is poor installation. What about difference in color of the car where it's covered & not covered?:rolleyes:
    Thanks again,
    Pat
  4. 08 mag grey
    08 mag grey New Member
    34
    Tucson AZ
    I've only had the 3M bra on my Prius for a month but I've had it on a '01 Corvette for 6 years and it did not yellow one bit. The bra is a little more noticable on darker colors than lighter ones but unless I point it out to people on my Magnetic Grey no one sees it. It's great protection.
  5. direstraits71
    direstraits71 Member
    367
    64
    Central Coast California
    I also have the 3M product on my 02 Solara. Its been on since 2002 with no yellowing or any other problems. The car sat in the sun all day during the week for 4 years and was garaged at night. I liked it so much I have installed it on my 2008 Prius which I just got on July 4. Both cars are silver and unless the light is just right, the kits are basically invisible. Its an easy self install if you stick to mostly flat surfaces. No problem with the hood and front of the fenders. I tried a vinyl kit for the lights, but was not able to deal with the curvature. The more expensive kits are urethane which works much better. I found on the Solara that the metal surfaces have more problems with chipping than those of plastic so be sure to cover those.
