How long should replacement wheel bearings last?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priusrecon, Jul 28, 2020.
  1. priusrecon
    priusrecon Member
    130
    45
    Upstate NY
    Ok, so out of an abundance of laziness last year, I took my 2006 Prius with 160,000 miles on it to a professional mechanic to get the failing front wheel bearings replaced. I figure as I get older and my back is bad, I'll just pay and let a professional worry about it and then be done with it for many, many years, or the remaining life of the car. And he is a Professional, so he'll do it right, Right?
    That was last summer.
    Around April/May of this year, I start getting new rumbling noises out the front end. It started while only turning in the one direction, but then it quickly developed into occuring turning in either direction, and also while driving straight ahead anymore....And as of today (July), it sounds like I'm always driving over rumple strips, I cannot even hear my radio if I turn it on, and my front tires have worn down to the cords on the outsides.
    Can the bearings have failed already, or is there another issue I need be looking into? The car sailed thru inspection in March of this year.
  2. Rmay635703
    Rmay635703 Senior Member
    2,670
    1,697
    Somewhere in Wisconsin
    2013 Chevy Volt
    Aftermarket Bearings are quite difficult to source these days.
    if anything other than Timkin or National was used you can experience failure out of the box.
    if you plan on keeping the car a long time
    And can locate a Toyota dealer with a lifetime warranty on repairs
    bearings are one of the few things worth a slight overpayment as most are total garbage
    mjoo likes this.
  3. jessiejosco
    jessiejosco Member
    62
    42
    Not even sure about Timken or SKF anymore. Both used to supply the actual OEM "Koyo" wheel bearing, but now both supply bearings made in China that don't have their name stamped into the race. I just replaced one a shop replaced a year ago. I don't know what brand they used, but I used one of these Timkens, so we will see how long it will last. The Koyo bearings have pretty much averaged about 70000 miles for me. That's not great considering what a pain they are to replace.
    I think the lifespan depends on where you live as well. I live where there is snow and salt on the roads and this is hard on wheel bearings. I suspect they last longer where there is not snow. Then again we don't seem to have as many battery failures up North.
    52,475
    an oem bearing should last a minimum of 60-80k
  5. Kenny94945
    Kenny94945 Active Member
    859
    434
    Sausalito
    2016 Prius v wagon
    I agree with Bisco's "life" estimate.
    Sure the bearings could have failed, especially if the bearing brand was inexpensive aftermarket.
    Plus, as mention snow zones, salted roads, water, corrosive wheel cleaners, power washing do not add to a bearing's life.
    Could be something else.
    Can you lift the car and begin inspecting yourself?
    Look for a loose under fairing, broken plastic wheel liner, loose sway bar, loose shocks, bent rotor shield etc.
    No joke, a hammer can be your friend in looking for loose parts.
    Good luck.
  6. Leadfoot J. McCoalroller
    8,160
    7,664
    Pennsylvania
    2018 Prius c
    In the early 2000s I started seeing a lot of the big-name bearings failing much closer to their existing warranty limits. I don't know what changed, but I no longer expect more than 75k out of the best of them and often see the cheap ones fail before half that.
    The noise they produce gains so gradually that most drivers don't even notice it until they're somehow given a chance to compare to new.
  7. priusrecon
    priusrecon Member
    130
    45
    Upstate NY
    I'm going to replace the bearings again, this time myself, to save the $700 labor cost per wheel.
    There is no lifetime warranty that I can find from the Toyota dealer here, in spite of their premium costs, they only offer 12 months on the original Toyota manufactured part and their installment. They wouldn't even guarantee that their diagnostic detected the correct wheel to replace, so I'm a bit leary of mechanics right now.
    I don't know the brand used on the 1st replacement attempt on the left side last year, but the 2nd time was a Moog, and the 3rd a Beck Arnley, and the right side was also a Beck Arnley. All of them failed since last year.
    Any recommendations of the best brand to use this time?
    I usually go for the best brand for longevity, but now I'm wondering if I might be better off just buying the cheaper ones if I'm only going to get a year out of them and have to keep replacing them every year anyway....
    What do you think....?
  8. bisco
    52,475
    did you ever go back and talk to the mech?
    i suppose if i were going to do my bearings, i would buy them from a dealer. maybe an online toyota parts site, if i trusted them.
  9. priusrecon
    priusrecon Member
    130
    45
    Upstate NY
    The mech closed due to COVID, and can't be found anymore. Before that, he was a fixture around here for more than 30 years. I knew him for a long time. Unfortunately, that doesn't always insulate you from taking it up the arse sometimes.
  10. AndyFromWI
    AndyFromWI Junior Member
    37
    Cumberland, WI
    I have replaced 7 bearings, a combination of front and rear, The first one was a Timken, the rest I have been Toyota OEM, from around $150 each. The job is not too bad. If you do the rear, you can use four bolts to force the hub off the axle. For the front, take the control arm off, then you can use 4 bolts to push the hub off the control arm.
    My Timken front has 52K and still going strong.
    On all of the different gen 2 prius, the bearing had between 180-230k miles before I replaced them. Some of the bearings have over 250K and still going strong.
    Video tips for using 4 bolts to replace the rear bearing:
    -andy
    Isaac Zachary likes this.
  11. Leadfoot J. McCoalroller
    8,160
    7,664
    Pennsylvania
    2018 Prius c
    Bet it rides nice and quiet now! (y)
    People are often surprised by how much difference it makes.
  12. AndyFromWI
    37
    Cumberland, WI
    Here was the worst wheel bearing. My friend had just driven it 300 miles. I did not want to take the car about 45mph until I replaced the bearing.
    -andy
  13. priusrecon
    priusrecon Member
    130
    45
    Upstate NY
    Just an update and a warning.....
    Warning....DON'T TRUST MECHANICS, even if you think you know them!
    When my guy said he replaced my left front bearing with a new one, after replacing the entire steering knuckle carrier with a salvage yard one, he lied. He just left the original 14 year old bearing that came in it and Hail Mary'd the fix, telling me he put a new bearing in there and CHARGING ME for a new bearing. I discovered that after I pulled the carrier off and found 14 years of rust and corrosion on the casing of the old original wheel bearing and having to beat off the old frozen on bolts and drive the thing out.
    So I replaced it with a brand new Beck Arnley, and it's now Cadillac'y quiet and velvety smooth. Forgot how nice that feels.
    Hopefully, it will last.
    Incidentlally, the guy is reopening his shop again after his COVID break, and I will certainly never go to him again....
    Prius Rising and Isaac Zachary like this.
  14. Isaac Zachary
    Isaac Zachary Senior Member
    2,689
    1,398
    This has been my experience with most mechanics. Get hunderd or thousand dollared to death to find out they did a bad job.
    The only problem is when there's an expensive tool that you might need but can't find it for rent anywhere.
