How long to leave prius on w/out moving?
Discussion in 'Gen 2 Prius Main Forum' started by shawn7, Jan 16, 2006.
  1. shawn7
    shawn7 New Member
    55
    Beaufort South Carolina
    We have a local Drive In movie here in town and was wondering if the battery would hold up during the show? My Denali is a pain because if you cut the ignition on, the lights automatically turn on.
    Thanks,
    Shawn
  2. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    kinda hard to say. summer before last, i sat for almost an hour waiting on someone (they said they were gonna run in and run out). it was hot so had air going.
    you could leave it running until you run out of gas as the ICE will cycle on automatically to charge the battery.
  3. Howard
    Howard New Member
    72
    Valencia, California
    Drive in Movie. Where could this be?
  4. Brian K
    Brian K New Member
    152
    Yup, Dave's right. Just make sure you have gas and everything'll be OK. The car will do what it needs to in order to stay healthy.
    FWIW, there's still a drive movie theatre in Skowhegan, Maine. As well as an absolutely beautiful restored old theatre in town Skowhegan. Skow town is where "Empire Falls" was partly filmed.
  5. iluvmacs
    iluvmacs Member
    280
    104
    Madison, WI, USA
  6. geologyrox
    geologyrox New Member
    513
    Last I heard, there was one just outside Columbus, OH. Two screens, two movies each per night. I miss it!
  7. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    Take a look at:
    http://www.driveintheater.com/
    They have a list of a lot of drive-ins around the US. Not totally sure how up-to-date it is, but it's a good starting place.
  8. mdmikemd
    mdmikemd Member
    436
    Minneapolis
    Don't drive-in's use FM receivers? Think about bringing a battery powered boombox.
  9. AlphaTeam
    AlphaTeam Member
    643
    Earth
    The one by us has those little crappy speakers if you get there soon enough.
  10. shawn7
    shawn7 New Member
    55
    Thanks for the replies. I'll make sure we have plenty of Gas prior to going.
    Ours just changed to the FM deal. I'm located in Beaufort SC. I think there is one other in the state or it's in Jessup GA... can't remember.
    ~Shawn
  11. richard schumacher
    7,663
    1,038
    United States
    Yes, leave it running ("Ready" in the dash display) and in PARK, not Neutral. In Neutral it will not recharge the main battery and you will be hosed. If it is not "Ready" it will not recharge either battery and you will be doubly hosed.
  12. aaf709
    3,862
    2022 Prius Prime
    I saw on a thread (before the crash) where they simply pressed the Power button to ACC and had the MFD off for the duration of the movie. It should just make it, as long as it isn't one of those 2 and a 1/2 hour long ones.
  13. fatale
    fatale New Member
    28
    Toronto, Canada.
    I just learned the hard way that the Prius' standard battery won't do much justice on its own. One movie maximum with the car in accessory mode (pushing the start button with your foot off the gas). After two movies, I needed a boost - and boosting is a pain with that little tiny + terminal. Oh well.
    Luckily there was a tow truck driver (with tow truck) watching the same drive-in movie. Unluckily for me, he wasn't feeling too generous and grabbed $20 off me. Doh! I agree with other people in that leaving the car on would be just fine. The only thing that would drive me crazy, is seeing all the dash gages. I am almost tempted to install a second battery in the rear spare compartment...
  14. Godiva
    Godiva AmeriKan Citizen
    10,339
    Anyone done a MobMov?
    Mobile Movie
    Seems like this is designed for the Prius.
  15. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    I've left the Prius running all day while camping, with just the fridge plugged in. The amount of gas you have is the limiting factor, because the car will turn on and off as needed to keep the batteries up. It'll turn on more often at a movie with the stereo and the air conditioning on, but you should be fine as long as you don't run out of gas. Or popcorn. :)
  16. Soylent
    Soylent The v isn't a station wagon! It's just big boned
    443
    Fort Lauderdale, Florida
    2013 Prius v wagon
    On your Denali, wouldn't lifting the handbrake turn off the headlights? I know volkswagens do this.
  17. J.Wilkie
    J.Wilkie 80 Mile Daily Commute
    157
    Behind The Orange Curtain
    On my Chevrolet truck I was able to turn off the headlights this way.
    Next to the knob you turn lights on, there is a small button about 1/4" in size. If you push it 3 times the headlights will turn off. If you push it once more the lights will come back on.
  18. DaveG
    DaveG Member
    806
    Vancouver, BC
    <div class='quotetop'>QUOTE(fatale @ Jul 24 2006, 12:21 AM) [snapback]291336[/snapback]</div>
    Just a reminder that you don't need to get the booster clip on the small threaded bolt at the jumper terminal, you can attach quite easily to the metal flange that comes up from the bolt, even with large cables.
    Dave
