How long will a Prime battery last and how much is a replacement?
Discussion in 'Prime Main Forum (2017-2022)' started by Alex Waltz, Oct 17, 2020.
  1. Alex Waltz
    Alex Waltz New Member
    2020 Prius Prime
    I keep hearing that the battery is the most expensive part of a hybrid car. I've also heard some horror stories from Leaf owners who essentially have EVs that are worthless because of depreciation and the high cost of a battery replacement.
    I'm just wondering, with the Prius Prime,
    1. How long will the battery last on average?
    2. How much is a replacement battery?
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
    We have two Priuses [Prii ?]
    Our oldest has a bit over 200k miles on it. The dealership service manager has told me that have been seeing many Priuses with over 300k miles on them, without any battery issues.
    I don't like it that the Prius has no error codes in it to check the 'health' of the battery. Either it works or it does not.
  3. Tideland Prius
    16,681
    The hybrid battery has a 10 year/240,000km warranty for any 2020 or newer Toyota hybrid vehicles so you're covered there.
    Hybrid batteries have lasted between 10 years and 15 years+ and 200,000 to 500,000km so there is a wide range depending on usage.
    The Prime isn't old enough for replacement so we don't know the cost but I'm guess it'll be a hefty sum given its size (cheaper than LEAF for sure but more than the regular hybrids).
    We were quoted CAD$3,000 for our 2005 Prius replacement battery (I think that included labour IIRC). It failed at 245,000km/11.5 years old and was mostly city driven.
    Oh and we never replaced the brake pads over that 245,000km because of regenerative braking (Yes, that includes the front pads).
    Tips likes this.
  4. Elektroingenieur
    2,515
    3,288
    Three Touring
    As with the older Prius Plug-in model, the HV battery typically wouldn’t be replaced as a unit because of wear; instead, one or more of the five HV supply stack sub-assemblies (part numbers G9508-47230, G9509-47030, G950A-47030, G950B-47030, and G950C-47030) would be replaced. These are shown as “No Longer Available” on parts.toyota.com, but I doubt that’s correct, though dealers may have to make special arrangements to get them. Other sources give the list price as $3,336.51 each.
    I have no idea whether that price might change as demand for non-warranty replacements increases. The list price for the same parts in Japan is ¥91,500 each, which suggests that Toyota may have some pricing flexibility, even after U.S. tariffs, transportation costs, and dealer markup are added.
    The Repair Manual (more info) describes many battery-related diagnostic trouble codes (DTCs), but I take your point: I don’t know of a convenient way to estimate the remaining life of the HV battery, until it’s reached a failure threshold that causes the car’s computers to store a DTC.
  5. Prim.e.xample
    Prim.e.xample Active Member
    164
    107
    Indiana
    2020 Prius Prime
    Toyota states that it will last the life of the vehicle on the Prius Prime website: "The battery in Prius Prime is designed to last for the life of the vehicle."
    I've concluded that IF I keep it long enough for the battery to fail, and it isn't covered under any warranty, then I'll have a regular Prius from then on.
  6. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    If your traction battery actually fails (RED Triangle of Death) then you won't even have a regular Prius, it won't get to READY mode. Also, the warranty covers battery failure, not simple degradation over time. Degradation will be indicated by loss of EV miles on a "full" charge, i.e., the battery will lose its charge more rapidly than you've been used to and you won't be able to drive as far on battery alone.
    Prim.e.xample likes this.
  7. The Big Sleaze
    291
    68
    'frisco
    2020 Prius
    Two Eco
    I'm seeing them on Ebay for $1000! :)
    I'm also seeing lightly crashed but "totaled" Primes with under 20K selling for under $4K!!!
    IMO two main reasons for this:
    a) Prime is going to be near 100% reliable for first 10yrs, so no market for used parts.
    b) Prime has CARBON FIBER rear hatch, and is "semi-Monique unibody" which means even a mild crash that leaves it perfectly able to drive around like before, is still not going to be able to be repaired to "good as new" as required in an Insurance Company/Legit Body Shop situation.
    IMO, this also makes Primes fairly safe from being stolen. Why try to defeat fancy factory security for your chop shop if you can legit buy nearly perfect Primes for cheap?
    Spam Trash likes this.
  8. Prim.e.xample
    164
    107
    Indiana
    2020 Prius Prime
    Oh man, I didn't think about not being to start it. That would be my main area of concern then. Anyone who buys an EV though hopefully knows that the batteries will degrade in EVs over time. Have to keep that 20% or so going!
  9. Moving Right Along
    Moving Right Along Senior Member
    739
    596
    Most hybrid and EV batteries are warranted for 8-10 years. Prius nickel hydride batteries are known to be practically problem free for that amount of time as well. Prius lithium ion batteries have not yet been around long enough to know for sure. I’d say if you’re the ultra cautious type, trade in the Prime after 10 years. Otherwise, jump through that hoop when and if you come to it. Past the warrantee period, there are a lot of different factors that can affect battery longevity: ambient temperature, charge speed, discharge speed, length of time at extreme charge states (full or empty), as well as small differences in the individual cells. The battery may fail on year 11 or 22 or 33 or anywhere in between, with greater likelihood the older it is and the more the small factors add up.
  10. Spam Trash
    Spam Trash Junior Member
    Rochester, NY
    2020 Prius Prime
    I paid $1k at a salvage yard.
    Starship_Enterprius likes this.
  11. Spam Trash
    Rochester, NY
    2020 Prius Prime
    I paid 15k for a 2020PP with 36k miles
  12. bisco
    52,862
    sounds like an excellent price, anything wrong with it?
