How Many Bicycles Do You Put on Your Hitch Carrier?
Discussion in 'Gen 2 Prius Main Forum' started by gordonr, Jun 2, 2005.
  1. gordonr
    gordonr Member
    117
    Massachusetts
    Still have a month or two more before we get our Prius. From reading this site I'm already learning lots of things ahead of time. Carrying bicycles is important to me, so I ordered the Coastal Tech 2" hitch.
    Speaking to Coastal, they said both the 1 1/4" and 2" receiver hitches are rated at 200 lb tongue weight. From what I've read, this is consistant with typical 1 1/4" units whereas 2" units are typically 350+ lbs. Generally, most manufactuers will only build 1 1/4" (i.e. 200 lb tongue weight) hitch bike carriers to only hold 2 bikes, and the 3+ bike carriers are usually 2" hitch units.
    All theory aside, how many bicycles are you carrying via your Coastal Tech hitch receivers?
  2. Devil's Advocate
    922
    Las Vegas, Nevada
    Go with the rating.
    200lb tongue weight is actually higher than it appears. I used to tow two Seadoos on a trailer with an 1 1/4" 100lb tongue weight hitch and receiver. (dodge Avenger)
    the real issue is what bikes are you carrying?
    for really good race bikes will only weight about 70lbs total, four good mountain bikes only weight about 120-130 lbs. well under any two hundred pound limit. even with the rack unit itself.
    I'm getting this one - its a little big but oh well http://www.performancebike.com/shop/profil...ategory_ID=4411
    Only the $50 cheap knock-off bikes from places like Costco, you know bikes that look like expensive bikes with shocks and stuff but weight about 3 times as much, will you have a concern with weight. (granted though these are good bikes for people who can't afford really good bikes but they weight a freakin ton)
  3. gordonr
    gordonr Member
    117
    Massachusetts
    Devil -
    When they rate something at 200 lb tongue weight, do you just add up the weight's of the bikes + carrier or do you have to account for some type of dynamic loading for when you go over bumps?
    If money is no object, the rack from:
    http://www.1upusa.com/1upusarackhome.htm
    looks real nice. The Sportworks Transport racks are also great (Sportworks sold their consumer product line to Thule, so hopefully Thule will continue to sell these very nice racks).
  4. Karkus
    Karkus Junior Member
    38
    Boulder, CO
    2019 Prius Prime
    Bike carrying was also a VERY important factor for me, but I prefer to carry them inside the car. Are you aware that 2 mountain bikes will fit inside a Prius pretty easily ? A medium full suspension bike (4" fork) will fit inside without even taking a wheel off, and the second one just requires front wheel removal. With 2 bikes in, you can still see out the back no problem. (You could probably fit 3 if you took wheels off). I just use an old bedsheet which covers the entire back area for carrying bikes, and the car has stayed amazingly clean even after several dozen bike carrying trips.
    It sounds like you want to carry more than 2 bikes, but for those times when 2 is all you need, putting them inside works great (plus it won't reduce your MPG like a rack will.)
  5. Devil's Advocate
    922
    Las Vegas, Nevada
    Tongue wieght is a dead load measurement. The live load rating is in the thousands of pounds and is a factor of the tensile strength of the steel and its thickness. You could never give this rating and have people know what kind of dead load can cause that "live" load. Plus you would have people way overloading hitches until the hitch pulls off the back end of the car.
    Try looking at this rack. It is standard as a two bike system with the option of addinf a third or fourth rack.
    http://www.thuleracks.com/thule/product.as...id=8&sku=260120
    I don't quite like the way the rack you show holds the top wheels of the bike. have neer seen one like that personally.
  6. Devil's Advocate
    922
    Las Vegas, Nevada
    Karkus,
    you're right you can put bikes inside, but I have the Ivory interior and the potential to inadvertently get oil, grease or dirt on the interior is way to great. I will sacrifice 5 MPG over a greasy dirty interior when I carry bikes anytime. Especially since I do not carry bikes as often as I drive.
  7. gordonr
    gordonr Member
    117
    Massachusetts
    Devil's Advocate -
    Thank you for the explanation of tongue weight, and for the link to the Thule site. I'm very glad to see that Thule is selling the rack designs they acquired via their purchase of Sportworks. I have used the first generation Sportworks Transport, and it works very well. I'm sure the second generation one you linked to is even better.
    I've only once seen the 1upusa rack on a vehicle. It appeared very nice and also well designed. I believe it's one significant advantage is that it's much lighter weight than the Transport as it's CNC machined aluminum (and hence the very high cost).
  8. gordonr
    gordonr Member
    117
    Massachusetts
    Just curious if anyone has direct experience carrying 4 bikes with a hitch mounted rack on their Prius? I know the weight should be OK (without a huge margin), but there is something comforting about hearing of people who have actually done it without problem. I'd hate to be far away from home on vacation and start seeing some issue.
    FWIW, I've been doing 2 bikes without any issues.
  9. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    <div class='quotetop'>QUOTE(Devil's Advocate @ Jun 3 2005, 01:00 PM) [snapback]95319[/snapback]</div>
    One does need to recognize that tongue weight of a trailer is 'adjustable' by properly loading the trailer. You could put everything in the back and end up with a negative tongue weight, lifting the rear of the towing vehicle.
    If it is dead weight, like bike carriers, it is all additive - weight of the rack plus weight of the bikes.
    Thus, you COULD have a small trailer weighing 200 pounds carrying four 50 pound bikes. The proper tongue weight (10% to 15%) would be 40 to 60 pounds. Substantially less than the 4 bikes plus the weight of the rack.
  10. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    <div class='quotetop'>QUOTE(Devil's Advocate @ Jun 4 2005, 05:12 PM) [snapback]95621[/snapback]</div>
    $3 is all you need to prevent grease.
    That's what I bought a tarp for. It works great. The blue side is the clean side. The silver, which matches the interior color remarkably well, is what the bikes are laid on.
  11. eyeguy13
    eyeguy13 Member
    337
    Vermont
    I normally carry one bike on my Coastal 2" rear hitch and Yakima rack. I carry two if me and a friend are going somewhere, but usually, it's just me and my road or mountain bike.
    I've modified the Yakima rack so it sits lower behind the rear spoiler:
    [attachmentid=4503]
  12. spinjunkie53
    spinjunkie53 New Member
    50
    Long Island, NY
    I've got the grey interior and have Exact Mats covering the entire rear cargo area. Just about every weekend I carry 2 road bikes (1 with front wheel removed and 1 with both wheels left on) inside the car, separated by a yoga mat. Thus far, the interior has stayed pretty clean as long as I am careful putting in and taking out the bikes.
  13. Scott_R
    Scott_R Member
    405
    Long Island
    <div class='quotetop'>QUOTE(spinjunkie53 @ Aug 15 2006, 09:13 PM) [snapback]303836[/snapback]</div>
    I was debating getting the Exactmats, but thought that since the bike would likely be on its side, the sides of the cargo area would likely get dirty. That said, why not a heavy tarp? The bike would go on top, and the sides of the tarp can be folded over it, keeping the interior walls clean.
  14. molgrips
    molgrips Member
    199
    I use tarps for my bikes - I usually take one or two plus a ton of camping gear. It gets tight with two if I want to be able to see out of the lower rear window, but if I don't care about that then it's fine. Putting the bikes in and out requires care, but you can keep your interior clean :) It helps to take the pedal off the lower side so it doesn't put dents in the carpet... I'm thinking of using my bike bag instead, super-easy to just slide in and out, and total protection.
    eyeguy13, that's totally illegal in the UK - it obscures your lights and license plate...
    Anyone have experience of roof-mounted racks? How much MPG do you lose?
  15. mtsarpilot
    mtsarpilot Junior Member
    87
    <div class='quotetop'>QUOTE(gordonr @ Jun 2 2005, 08:09 PM) [snapback]95120[/snapback]</div>
    My guess is the 200 lb limit has to do with how the hitch is mounted to the car and nothing to do with whether the receiver is 1 1/4" or 2". The hitch is bolted to the tie down points in the frame. It is using the same bolts as the tiedown was in with. By nature of the design, it hangs about 4 inches down before progressing rearward. That means there is some cantilever action there. The more weight you put on that hitch, the more stress on those bolts and the more downward twisting motion on the hanging brackets. Hit some big bumps and you have added a lot more dynamic load. They want to keep it load limited within reason.
    I have the 2" receiver from Coastal and the Thule Trailblazer 4 bike rack. It is the one that swings out of the way so you have full access to the back of the vehicle when bikes are loaded on the rack. The Prius hatch can open without swinging it out of the way, so that feature is not needed for a Prius. I bought the rack a couple years ago because our Honda Pilot needs the swing away in order to open the rear. I have put the rack on the car as a test, but I have not had an opportunity to load it with 4 bikes yet in the week I have owned the car. Should work just fine though. Will be interesting to see what it does to gas mileage.
    My usual is just 1 mountain bike. I chose to go with the hitch instead of loading them inside to keep from damaging the interior. I have tossed the mountain bike inside my Subaru Outback for many years using a tarp for protection. Even with the tarp, over the years the side panels have gotten chewed up from the handlebars and the chainrings. Then you also have to be careful to make sure the tarp is in all the right places around the bike. I decided it was going to be earsier to just toss the bike on the rack and roll.
  16. rudiger
    rudiger Active Member
    696
    45
    Cincinnati, OH
    I carry a Long WheelBase (LWB) Linear recumbent in the back of my Prius. The front and rear wheels fold under to make it much shorter and I also remove the bike's seat. Being able to transport the bike in this manner was a major consideration in purchasing a large hatchback-style vehicle.
    I have the cargo area Exact Mat but also use a large piece of cardboard that covers both the floor and sides of the cargo area. I use the rear seatbelts to hold up the sides of the cardboard when loading/unloading the bike.
  17. gordonr
    gordonr Member
    117
    Massachusetts
    mtsarpilot -
    I also have the 2" Coastal hitch, and 100% agree that in this case the size has nothing to do with ratings. Most hitch manufacturers won't make a 2" version if it isn't classified beyond class II (greater than 350 lb tongue weight). In a sense it's nice that Coastal gives us the option, but clearly the Coastal-Prius is a Class I hitch at best. You generally have more choices in hitch mount bike carriers if you have a 2" hitch, but there is also more opportunity to abuse the setup when it's 2".
    I really don't know what kind of engineering analysis hitch makers typically do on their products, but given the casual way Coastal operates, I accept that I'm probably on my own should a problem occur. I've never seen a two piece bolt together hitch from the mainline hitch makers (Hidden Hitch, Curt, Draw-Tite, Reese), so this design philosophy doesn't have a lot of miles of experience under it's belt. The Curt/Da'Lan 1 1/4" design for the Prius is a one piece setup but does require that you cut the plastic trim under the car.
    My physics is kind of rusty, but should the 200 lb tongue weight have any derating due to the cantilevered nature of a bicycle carrier acting as a load at the end of a lever? I was reading the FAQ's of an obsure bike carrier maker (http://www.alpacacarriers.com/faq.htm) who suggest that you should not exceed 65% of the tongue weight rating because of this factor. For the Coastal hitch this would be 130 lbs. This is also on the edge of a typical hanging rack style setup where the rack can weigh 30 to 40 lbs (other rack designs can weigh double this figure for a 4 bike setup), and a general budget of 25 lbs / bike would put a typical 4 bike setup in the 130 to 140 lb range.
  18. davidf
    davidf New Member
    I've got the Coastal hitch and used it last week for our vacation. I have a Thule 4-bike rack, and ran into some problems.
    We put 4 bikes on the rack (not especially light bikes by any means). The dead weight appeared toward the limit, but holding (sort of). We traveled about 150 miles, and when I got to our destination, I noticed the hitch had 'bent' down about an inch below where it was when we started (I did confirm that the hitch was still tightly attached). I suspect this was due to natural 'bouncing' on the highway. It bent enough that I didn't feel comfortable transporting the bikes back home again (we had a friend bring them back for us).
    I haven't had a chance to look underneath the car and see exactly what went wrong, but it seemed that at least our 4 bikes was too much for the hitch.
    Not sure of where this is ultimately leading (a different hitch, don't carry 4 bikes, etc.)...
  19. bruceha_2000
    3,054
    301
    Northwest VT
    2018 Prius Prime
    <div class='quotetop'>QUOTE(davidf @ Aug 16 2006, 11:49 AM) [snapback]304117[/snapback]</div>
    What is the total weight of the bikes and what is the weight of the rack? I ask because we have 2 Sun EZ Racer AX medium wheelbase recumbants that weigh 34# each. One will fit inside the Prius with 3 seat backs down (2 rear seats in the Prius, 1 on the bike ;) ) I don't know what the kids' 24" mountain bikes weigh.
    I got, but have not yet installed, the 2" Coastal receiver figuring 2" would give me more flexibility in bike rack/rear platform carrying options. With your experience, I'm thinking my long term plan of getting a light weight 4'x4' trailer and making custom bike mounts is looking better all the time. A LOT less weight pushing down on the hitch.
  20. bacinmass
    bacinmass Junior Member
    29
    Outside Boston, MA
    Here's another way to haul bicycles and kayaks... and no back strain putting the kayak on the roof!
    http://www.sportsrig.com/
    Has anyone purchased one of these? I am considering it, but would like to hear someone's first-hand experience first.
