How many Charge every time?
Discussion in 'Prime Fuel Economy & EV Range' started by lmans66, Jul 17, 2018.
  1. lmans66
    lmans66 Junior Member
    53
    24
    Arizona
    2018 Prius Prime
    Now, I have had this Prime for only a week, so not much data here to draw from. But had a Prius for 11 years prior, so love the cars.
    But, when I return from an errand...I recharge. Even if I am down only 20% or so, I recharge. How many others do that?
    Does recharging when not in need of a full charge, does it hurt the life of the battery?
    Arctic_White likes this.
    52,408
    it is an unknown. toyota recommends not leaving the battery fully charged for long periods of time, and we know that lithium ion prefers to be in a discharged state.
    for those two reasons, i work hard to figure my driving patterns, leave the pip battery discharged as much as possible, and keep it half charged when i'm not sure, so i only need 30 minutes on my L2 for a 90% charge.
    srivenkat and Bill Norton like this.
  3. ClemsonSteve
    ClemsonSteve Active Member
    270
    248
    South Carolina
    I don't think it matters how often you charge. So, yes, I'm always chagrining, unless I know I'm not going anywhere until the next day, when I delay the charging until 1:00 am to ~6:00 am. I depart for work around 6:55 am.
  4. Son of Gloin
    Son of Gloin Active Member
    421
    320
    Lafayette, IN
    I'll take a swing at answering your question, but only in a strictly NON-technical manner:
    For the first several months of Prime ownership (from last August to March or so), I would typically charge ONLY after the car switched from EV to HV on its own... when the traction battery was too low for EV (only) use. I did that MOSTLY in an effort to determine the "total" EV range (*) in my particular circumstances and driving "patterns" (retired / no daily commute / strive to consolidate errands / etc).
    (*) "Total" EV range for PIPPIN on a full charge has been as low as 18.4 miles when really cold outside and as high as 36.3 miles.
    But as spring / warmer weather arrived, I started to re-charge at the end of any planned driving for any given day IF the car was down to, say, less than 10 or 12 miles of estimated / remaining EV range... OR whenever I thought the next day's driving *might* exceed the car's EV range. I do it that way now MOSTLY to absolutely minimize how much - if any! - gasoline PIPPPIN burns in strictly LOCAL / in-town driving.
    As an aside (?)... my current strategy seems to be "working". I've driven a total of about 485 miles since last filling up the tank and, INCLUDING a roughly 145 mile trip to-and-from Indy, the fuel gauge shows MORE than 3/4 of a tank remaining, and PIPPPIN (a Premium) "thinks" he's "maxed-out" in MPG... showing 199.9 mpg for the tank.
  5. triggerhappy007
    triggerhappy007 Active Member
    498
    334
    I would not charge the battery if it's 80% or higher unless you know you will use up all the battery right away. It will lead to greater degradation but I don't have any data to back that up.
    Some reading material on lithium ion batteries which may or may not apply to EV:
    How to Prolong Lithium-based Batteries - Battery University
    #5 triggerhappy007, Jul 18, 2018
    Rob43 likes this.
  6. ed4271
    ed4271 Member
    107
    64
    US
    I thought that the battery is a 8 kilowatts. But it only charges up to 6.6 kilowatts. Am I assuming that the battery turns on the ICE when it depleted the 6.6 kilowatt. So you really not charging the battery to a full state. My math is not that good but I'm thinking that you'll only charging the battery 85% or 80% not sure. Because the battery has a 1.4 Reserve to use for the hybrid system when the 6.6 kilowatt is used up.
  7. Tideland Prius
    16,623
    If you follow John1701a's videos, you'll see that fully charged on the display is actually 80% or 85% true SOC so Toyota already built that into the BMS software.
    Yes, there's a small portion for the hybrid battery. Note that when you're charging 6.3kWh (or 6.6kWh in your case), you've actually only topped up in the high 5.x kWh (~5.5kWh) because you have to account for the heat generated when charging (RoT is about 10-15%).
    So taking 8.8kWh, subtracting 5.5kWh then taking about 1.0kWh for the hybrid section and you're left with 2.3kWh or 26% of the battery's true SOC. We estimate it'sa bout 15-20% at the top so it's about 6-11% at the bottom (but you'll never see it since the car will charge up the battery in HV mode with the engine like a regular Prius so you never see 0 or 1 bar equivalent using the old Prius terms. I realize the Prime and Gen 4 no longer use distinct bars in the battery meter, rather they use a fluid /continuous battery meter readout).
    Arctic_White, benagi and breakfast like this.
  8. Arctic_White
    Arctic_White Member
    30
    51
    Edmonton, AB
    I do multiple trips per day, so I do plan on charging each time I'm at home.
    Unfortunately, there is no charger at work and my total commute is ~35 kms both ways, meaning that I *should* be able to go all EV mode on most days. Fingers crossed!
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Just to point out something I didn't see mentioned. It's better for the battery's long term health to charge it before you leave rather than when you return. And to answer the original question, I charge every chance I get. I run about 95% EV.
    Tips, Arctic_White and Prius from Dad like this.
  10. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    Totally agree with charging for when you leave. I also charge (for departure) whenever I need to. In my current situation and with the current temps, I get 4 commutes and 1 shopping trip on 1 charge. Right now I'm about 99% EV. :)
    Arctic_White and jerrymildred like this.
  11. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    Whenever our Prime is at home, it's plugged-in. Entune will send us a text message, if it's not:
    Our systems indicate that your Bear-Mobile is near your primary or secondary charging location and was not plugged into a power source.
    Entune also sends a message when the car has completed charging.
    We've owned the Prime for two years this month and set up the Entune system about after owning the Prime for about a week. My email log shows 1257 messages from Entune over this period, with the vast majority being charge completion notifications.
    The fact that Entune sends an alert if the Prime is at home and not plugged-in suggests that Toyota intends that the Prime be plugged in whenever possible. Because I do not use a charging schedule, my Prime begins charging upon plug-in and ceases when fully charged.
    benagi and Arctic_White like this.
  12. Arctic_White
    Arctic_White Member
    30
    51
    Edmonton, AB
    Thank you for this. This is exactly what we intend to do: charge it as soon as it's parked in the garage and leave it plugged-in. This also allows us flexibility and certainty that the vehicle will be as charged-up as possible, as I do drive in the evening to pick-up / drop-off kids to their various activities.
    My goal is to use the EV mode as much as possible and to keep diligent track of KWH consumed. Yes, I'm a nerd. LOL.
    Prius from Dad likes this.
  13. Clark_Kent
    Clark_Kent Member
    44
    39
    Atlanta, GA
    2020 Prius Prime
    I bought the car to take advantage of the EV range. As such, I plug-in as often as possible and will continue to do so. I have ~700 miles on the car and all but ~10 miles are electric. The fuel gauge is still reading full on the original tank of gas from the dealer.
  14. Tha_Ape
    Tha_Ape Active Member
    271
    162
    Washington, DC
    I have mine "scheduled" to be fully charged when I leave in the a.m. When I get home i plug it in to the metered 120V but it doesn't start charging until ~1am.
    If i plan on going back out after coming home or it's the weekend, I'll "charge now" and plug it in the 240V outlet.
    Once it's fully charged, i unplug it, especially if there's a storm brewing. Had my place stuck by lightning before and had 1/2 my electronics fried, so I get nervous about leaving high value things plugged in
  15. allenbrown
    allenbrown New Member
    united states
    2012 Prius+ MPV
    I don't think it matters how often you charge. So, yes, I'm always chagrining, unless I know I'm not going anywhere until the next day, I have a Ram truck also which i use for Long Distance Towing services, so when i go for a drive so keep that for charging.
    #15 allenbrown, Sep 5, 2019
  16. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    I charge ALL the time, when our Prime arrives home at the end of the day there might be ~2 or ~3 miles left in it. We go out more often than not, so having a fully charged Prime is better for us, I don't like driving on the ICE if I don't have to. We use the 120v OE charger at 240v for fast 2 1/2 hour charging.
    Rob43
    Raytheeagle and Arctic_White like this.
  17. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    I charge all the time there are options too;).
    The kids like to help “fill the car up”(y).
  18. CraigM
    CraigM Active Member
    208
    208
    Portland, Oregon
    We are both retired, so there are few “hard” departure times. The Prime has about 10 miles remaining on the Guess-O-Meter tonight. Let’s say the wife says in the morning “let’s go to the mall” and I need an additional 10 miles range (9ish miles each way). NO PROBLEM, because she will require an hour to get ready, and that would give enough time to add an additional 15 miles. I admit that I don’t like to leave it with less than about 5 miles Incase we have to make an emergency trip to pickup a pizza
  19. Tideland Prius
    16,623
    Given the short recharge time, I don't. I usually plug for tomorrow's departure but if I need to drive out and I don't have enough charge, I can always go to the car and start the charge (no Prime Apps in Canada) - the lower the SOC, the faster the charge in x minutes (say 30 or 60 minutes). It's more than enough for city driving. If not, oh well, the engine needed running anyway :LOL:
  20. phlack
    phlack Junior Member
    32
    2020 Prius PHV
    Old thread, but new user here and I'm reading as much as I can.
    I agree with this statement. My Prime is a week old, and the tank has been barely touched.
    Especially with these days of Ethanol gas, I feel that it would be a good idea to run the engine every now and then, and probably rotate the tank every couple of months at most.
    My work commute to work is only a few miles; I can get there and back in 14% of EV usage...with the A/C running. So even with a little more in-town driving, that tank isn't going to be hit very often. And I don't forecast that changing anytime soon. I'll take any gas usage as a good thing! (can't believe I actually said that!)
    srivenkat likes this.
