How many gallons per fill-up do you dare
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Ichiro, Mar 29, 2012.
  1. Ichiro
    Ichiro Member
    335
    SF
    I've been getting about 7.5 to 8 gallons per fill-up...
    At which point does the the low fuel warning indicator light up? About 2 gallon left (out of 10.6)?
  2. iRun26.2
    iRun26.2 Active Member
    769
    151
    United States
    I haven't filled up yet, but I thought the tank could hold 10.9 gallons.
  3. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    I drove 2 more days after the last bar started blinking (with maybe 10 miles of HV at most, I'm guessing). When I filled up, it clicked off around 8.8 gallons. I filled it to $40 (trying to keep the number even since I'm using my $100 gas card I got from Dianne! thanks!), which came out to 9.1 gallons
    I think filling up 9 gallons or so is good for me. I used to fill up my last car before the light even came on (which was maybe 4 gallons left in a 19.8 gallon tank).
    I also thought the PiP tank was 10.6 gallons (and the regular Prius has a 11.9 gallon tank?)
  4. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    I thought Fuelly planned to add kWh entry?
    What are the Leaf and Volt users using?
  5. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    There's a thread in the Fuelly forum that is discussing the kWh issue. Im not actually following it. Like a few others on Fuelly, I just noted my EV/HV ratio and their respective consumption (kWh and gallons) in the notes section. I'm actually surprised there are so few Prius on Fuelly in general.
  6. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    In our Prius when the pump first click off you can still nurse
    another 2 full gallons in the tank with fuel being visible at the
    top of the filler neck.
    I know this is not good practice but if you have a long drive ahead
    with not many gas stations or many with gas over $5 per gallon
    it may not be such a bad idea. Thats an extra 100 miles
    which is a long way when you think about it...
  7. DonVentura
    DonVentura SoCal Prius Driver
    78
    Ventura, CA
    I drove around one more day after last bar was flashing. Today I put in 9.95 gallons, that's the most I've ever put in.
