How Many Miles Are On Your Prius?
Discussion in 'Gen 2 Prius Main Forum' started by Ryan M, May 12, 2008.
  1. Ryan M
    Ryan M New Member
    Please Post:
    Year Of Your Prius
    Miles On Your Prius
    Any Problems So Far? If So, What?
    Thanks!
  2. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    2800
    Only problem is the brakes squeek a little while backing out of my driveway but i'm taking it in this week and i think my alignment is off cause of the wonderful roads out here
  3. dogfriend
    7,512
    1,185
    Carmichael, CA
    2007 (In Service 2/25/07)
    Will have 19k sometime tomorrow.
    Delivered with bad rear alignment - fixed by shimming rear hub.
    Coolant Storage Pump makes nasty noises but still works.
    No other issues.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    2004 (got it Oct. '03)
    74000 miles
    MFD replaced, no major problems at all.
  5. Mozencrath
    Mozencrath Junior Member
    50
    115,000 miles - Oil changes every 6,000
    Zero problems of any type. Brakes still have plenty of life. Coolant is clean still.
  6. hobba
    hobba New Member
    85
    Estero, FL
    22,800
    No problems other than annoying rattles in the A pillar around the airbags...
  7. wb9tyj
    wb9tyj 2017 Prius Prime Advanced
    389
    94
    Indiana and Nevada
    88000 miles
    no problems... routine oil/filter changes/2 sets of tires/ and changed transaxle and inverter fluids...thats it...brakes still at 75%...
  8. johnval1
    johnval1 New Member
    26
    Commerce, MI
    31,000 miles.
    Absolutely no problems whatsoever.
  9. patrickindallas
    patrickindallas Shire rat
    676
    36
    Vancouver, WA
    '07
    22005
    Delivered with front alignment out of spec. Zero problems since.
  10. PA Prius
    PA Prius Active Member
    754
    241
    SE Pennsylvania
    87,900
    oil, filters, tires, steering recall, and an occasional tank of gas. That's it.
    PA P
  11. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    Late Aug 2006.
    17,600 miles - oil changes/tire rotations every ~ 5000 miles.
    No problems so far.
  12. Spectra
    Spectra Amphi-Prius
    3,123
    17
    S NJ
    What was the steering recall about !?!
    2008
    2250 mi.
    brakes feel more spongy than I'd like
  13. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    (2007) 13 Aug 2007
    10,700
    Problems:
    1. MPG dive after the first oil change/tire rotation; and
    2. I keep stopping at the gas station. The problem is that I go in and buy soda and a snack.
    3. Oh -- the paint seems to scratch easily. It could just be me and tough circumstances, but the finish seems particularly touchy.
  14. richard schumacher
    7,663
    1,038
    United States
    28000
    The dash squeaks sometimes, depending on the temperature.
    The mount for the glove box closer broke. I fixed it by adding a screw.
    The center console fabric was replaced under warranty after it started to pull away at the front.
  15. richard schumacher
    7,663
    1,038
    United States
    Some component was slightly under-designed: if it was stressed, for example by running into a curb, it was possible that it would break later. The recall work on mine was completed without incident so I didn't think it was worth reporting it as a problem.
  16. PA Prius
    754
    241
    SE Pennsylvania
    Exxon, Mobile, etc. filed a class action suite against Toyota because the Prius was steering away from gas stations.
    Or maybe it was the following--
    '04-06 Toyota Prius
    Under certain conditions, steering assembly could loosen or crack, possibly resulting in loss of control and crash.
    Models: 170,000 hybrid vehicles. Hazard may occur if steering wheel is turned forcefully to the locked position at low speed or if tires contact roadside curb while driving. There have been no reports of accidents or injuries related to this condition, according to Toyota.
    What to do: Have dealer make necessary repairs. For information, call 800-331-4331.​
    PA P
  17. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    2005 with 83K miles on it. Never been to the dealership except for the 2 recall notices -steering column and computer reflash if I recall.
    Oh, and my paint looks like new.
  18. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    2004 (early)
    34,500
    MFD failed (warranty)
    Glove box lock broke
  19. SeniorDad
    SeniorDad Junior Member
    44
    Terra Incognita
    March 31, 2007 (how con-vee-nent) Thank you taxpayers.
    4276 miles
    Returned for an alignment under warranty.
    Some knucklehead (that would be moi) turned out the dash lights when he installed his EV switch. 50% returned, the rest still searching for the microvoltage.
    Vehicle doesn't leave the right lane on the Freeway, no matter how hard I try.
  20. hill
    8,156
    Ryan, welcome to PC. Perhaps you didn't notice the stickys just above your post? There, you'll find the folks with 100k and above.
