How many miles can you put on a Prius before needing a new car?
Discussion in 'Gen 3 Prius Main Forum' started by ThereOnceWerePancakes, Jan 29, 2023.
  1. ThereOnceWerePancakes
    Charlotte, NC
    Hi yall,
    I read years ago about some dude that put like 400-something thousand miles on a Prius here. I was wondering how likely it would be to do that. My goal is to hit 400-500k. I think it's possible but am curious about your thoughts on what kind of problems you would go through before realizing it's not worth it.
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    723
    284
    Maine
    There is always the possibility that you got a lemon, of a Friday car. But if you can avoid those a Prius should be reliable to 300k.
    What I am seeing is all the plastic has become brittle. The wheel well liners, the body panels, and the undercarriage skid plates, have all gone brittle. The rubber grommets used to hold them in place have released. I have body panels that have cracked, and the best idea seems to be drilling a series of 1/4 inch holes and threading tie-wraps to hold them together.
    PriusG909 likes this.
  3. Leadfoot J. McCoalroller
    7,237
    6,784
    Pennsylvania
    2018 Prius c
    I'd say the key to getting 400-500k out of a Prius is to drive at least 26k miles per year.
    Lots of little things on these cars go soft somewhere between 15 and 20 years of age, regardless of miles.
    So I think of it as a buffet- all you can eat until closing time. If you don't show up hungry while dinner is hot, you won't set a record.
    CR94 and Moving Right Along like this.
  4. Todd Bonzalez
    Todd Bonzalez Active Member
    250
    160
    Ireland
    How long is a piece of string?
    I saw a Ferrari 360 a few years back that had 160,000 miles - even a traditionally "unreliable" car can be kept on the road if you've got enough money, mechanical skills or persistence. I've also seen people junk a car that just needed a set of tyres or a windshield
    Everybody's got a different breaking point is what I'm saying, I guess
    douglasjre and JohnPrius3005 like this.
  5. Grit
    Grit Senior Member
    6,152
    4,061
    Wilkes Land
    354,742 miles.
    PriusGuy32 likes this.
  6. Tombukt2
    Tombukt2 Senior Member
    9,596
    1,681
    Durham NC
    I'll make 600k in the next 3 years easily All of my Corollas from 74 SR5s all the way up to 2002 made over 300k with little or no fuss never an engine replacement nothing just breaks tires batteries and whatever little things humans want to put in their cars for whatever reason but Toyota has never let me down until the 2013 persona I bought because my wife liked the color instantaneously needed an engine and other miscellaneous parts etc I doubt this car will make 400k but it might with its second engine and other bits and pieces in it but I generally do not head to that car to get into to use I use my Gen 2 let the girls have the Gen 3s because they're parked all day at work. My Gen 2 is on the road making customer calls.
    douglasjre likes this.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,790
    2017 Prius c
    Impossible to answer.
    It depends mostly on LUCK and your tolerance for ongoing repeated maintenance headaches.
    Just like any car.
    Only maybe worse because of the big battery that is involved.
    JohnPrius3005 likes this.
  8. ColoradoBoo
    ColoradoBoo Senior Member
    985
    654
    Monument, Colorado USA
    It depends on a number of things...some aren't under our control...liking getting t-boned or hitting black ice and rolling her.
    If you really want to get her to last, you have to stay on top of maintenance and rust-protection. Rust can kill any Toyota and, even when maintained well, if the brake lines and frame rusts out, the car is toast.
    Find "The Car Care Nut" on YouTube and watch his maintenance videos...he even shows ruined engines on Toyota's where the owner only changed the oil every 10,000 miles. He has excellent maintenance videos and even talks about trouble areas to watch for in Toyota models...down to each generation.
    And learn to do your own maintenance like many of us in here. Right now, the only things I don't do are major suspension work on our vehicles and have learned to change any and all fluids. It starts with changing the oil and oil filter, the best thing you can do for any vehicle if you want it to last. (Every 6 months or every 5,000 miles...no exceptions and don't listen to folks who say hybrids/plug-ins can go a year or 10,000 miles...and engine is an engine is an engine.)
  9. Moving Right Along
    Moving Right Along Senior Member
    690
    541
    If you put on the average of around 15,000 miles per year, then your Prius is nearly guaranteed to last 150000 miles, and likely to last 180000 miles. That would be 12 years, the average age of cars on the road right now. At or beyond 12 years, it’s likely to start needing some $500+ repairs if it hasn’t already. I know my car has needed some. And from then on, it’s a matter of consistent maintenance, timing, and luck. No car lasts forever, so you have to determine for yourself the costs that would be too much and would convince you to move on to another car. It could be a single $3000+ repair or the collective cost to repair a number of things in a particular year or the fact that the safety equipment or entertainment options are out of date, or a number of other factors. If you really love your car, you can keep it until you run out of money or parts. But for most people, I would say a Prius is designed to last 12 years and 180,000 miles.
  10. taxidriver50005
    taxidriver50005 Active Member
    204
    170
    GB
    Excel
  11. Grit
    Grit Senior Member
    6,152
    4,061
    Wilkes Land
  12. PriusG909
    PriusG909 Junior Member
    17
    Los Angeles/IE
    I’ve only had them last to 220k most but I beat mine…
  13. rjparker
    rjparker Tu Humilde Sirviente
    8,102
    4,806
    Texas Hill Country
    First, you have to consider that only 3% will ever make 200,000. The rest will find their forever home in an auto salvage yard before making that number.
    Second, commercial users don't mind significant operating expenses because they normally have extra cars and they know where to get major mechanical work done fast and for a reasonable price. Taxi fleets are a case in point.
    Plenty of people get 300,000, some get four hundred thousand, but most of those will be replacing an engine, replacing the battery and fixing a lot of small things. With gen3, you have to include brake boosters, inverters and oil consumption.
    These days an engine or battery replacement is cost-effective compared to buying a new car, especially for those who value low operating costs over solid reliability. That was not the case before the pandemic and will not be the case in a year or two.
    What you don't want to do is to buy a high mile Prius today thinking you can get a reliable hundred thousand out of it. Especially since car prices are often $5,000 to $10,000 over valued and interest rates are high. The used car market is sure to crash - leaving today's buyers upside down. Those buyers will end up having banks repossess while their credit goes down the tube. Especially when an engine is needed and they are still making high payments.
    #13 rjparker, Jan 31, 2023
  14. taxidriver50005
    204
    170
    GB
    Excel
    Agreed, used cars are on the cusp of returning to there normal values. Tesla for example have just knocked off 6 months of there delivery times as people are cancelling there orders in the UK due to cost of living rises.
  15. qdllc
    qdllc Senior Member
    1,370
    399
    It’s all about regular use and maintenance. How “nice” your ride is after 200K depends on your driving habits and how well you take care of it.
    Moving Right Along likes this.
  16. Grit
    Grit Senior Member
    6,152
    4,061
    Wilkes Land
    o_O
    o_O
    o_O
    o_O
    o_O
    o_O
  17. bisco
    49,694
    mine only lasted 35,000 miles and the tires went. too expensive to replace, so i dumped it
