How many miles did you get from your 12v battery?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, May 28, 2009.
  1. ski.dive
    ski.dive Active Member
    959
    241
    Hutchinson Island,FL. Mt. Snow,VT
    Guys & gals:
    How many miles did you get from your toyota 12v battery before you had to replace it?
    What is a good aftermarket?
  2. richard schumacher
    7,664
    1,043
    United States
    About 35,000 over 55 months. A better measure may be the number of starts, in which case about 3300. Mine wasn't dead but the end was in sight.
    No direct substitute is known. Just about the only aftermarket is an Optima Yellowtop. ELearnaid sells them, fully charged, along with a nice installation kit. The kit is highly recommended. Without it you will have to devise your own adapter from the battery to the Toyota cables because the original battery terminals are small.
    Prius parts
    This approach is fun and the battery should be more durable than the original battery but it will not save much money, if any. Also consider the list of required tools: you will need all of them. If you do not have a bench vise considerable hand strength may be required to disassemble the Toyota positive connector assembly.
    The easy solution is to have a dealer do it.
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I just recently replaced mine with the Optima Yellow top from eLearning.
    I had approx. 92,000 miles on the stock 12v battery before I decided it needed to be replaced. I have a feeling I have the largest stereo system of anyone on Prius Chat and as such I beat the hell out of that poor lil battery. I drained it down 5 times during ownership. LOL
  4. chogan2
    chogan2 Senior Member
    1,066
    756
    Virginia
    Four years, 45,000 miles. Had a couple of cases where the car would only partially start -- couldn't drive it and couldn't turn it off until I put a charger on the 12V. With hindsight, I think I would avoid that if possible.
  5. halpos4
    halpos4 "Taxi"!
    377
    25
    Ireland
    Currently at 227,000klm[142,000mls]on my 06 Taxi,original 12v,no issues with starting but might change before end of year although winters in Ireland are mild,sometimes below freezing,but the fact i work nights,car rarely sits in freezing temperatures.Will probably change for OEM battery from dealer,€120,they don't charge for fitting.
  6. fred garvin
    fred garvin New Member
    376
    56
    northern virginia
    replaced at 105k on my 02 gen 1 - bought the $105?? oem battery from the dealer, installed myself
  7. PA Prius
    PA Prius Active Member
    763
    251
    SE Pennsylvania
    112,000 miles and counting.
    PA P
  8. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    150,000 miles, 62 months and still using the original 12v battery. If you never drain it, it will last a long time.
    JeffD
  9. JSH
    JSH Senior Member
    2,605
    140
    PDX
    56,000 miles and 56 months so far. I do plan on replacing it with a yellowtop when it needs replacement.
  10. Ogo
    Ogo Prius Owner since 2008
    220
    44
    Ilirska Bistrica, Slovenia
    If you use your Prius as a taxi every day for hours, then your 12V battery is never getting discharged much.
    The biggest killer of 12V batteries is discharge. When the voltage drops below certain point, battery starts to die.
    So people who do not drive their cars often and even when they drive them, they drive them only for few minutes, are the endangered species on the list of dying 12 V battery.
    Second factor is the age of the battery. But it is much less of a factor than discharge. I still have some 12 V led batteries which are over 10 years old and working fine. They are of course kept fully charged with professional charger.
  11. ski.dive
    959
    241
    Will the TOYOTA dealer charge me to install the battery if I buy the battery from them?
  12. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Who does free installs?
  13. ski.dive
    959
    241
    discount auto parts and auto zone will install the battery for free, if you buy from them.
    [ but they do not have a 12v battery for the prius ]
  14. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I'm sure there are stipulations in the fine print. I doubt they would install one in a Prius for free or a C4 Corvette (LOL). But I could be wrong. I see this all the time in the car audio world where places claim free installs but you get charged regardless. :(
    I doubt the dealer will install it for free but I wouldn't worry too much. They are quite easy to install, even if you do the conversion. I'd be more than happy to walk someone through the install process, on the phone if need be, just to help them save money and feel more confident in tackling it themselves. :)
  15. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    South Florida is murder on batteries; 2-3 years is all you typically ge before they die.
    I just traded my 2006 with 71,000 miles after 42 months with no sign of weakness.
  16. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    84,000 miles since Jan 06. No problems so far on OEM battery. My wife's Subaru lasted almost 9 years, and I replaced it because I was worried about it, not due to any actual problem.
  17. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Replaced the 12V battery at 54,000 miles and 7 years on the Gen I.
    Gen II needs to be replaced (11.3V w/ small load) at almost 115k miles and just over 5 years. SKS acts a bit wonky from time to time and MPG isn't as great as it could be and I suspect the 12V battery could be part of it.
    Silly me thought I could get creative and (at my dealer's suggestion!) trade the 2002 battery w/ the 2004 battery before trading in the 2002 tomorrow. Sadly, they're not the same battery, but I didn't discover this until I had dug into and disconnected the auxiliary batteries from both cars.
    Guess it's time to fork over the $$$ for another. Are the Yellow Top's worth the effort over an OEM replacement?
  18. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Hardly any more effort involved Rick. You could perform the swap in a snap. :)
    I just like the idea of being able to drain the Yellowtop over and over and not have an issue.
