How many miles on these spark plugs? 2009 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by eelfner, Jul 23, 2020.
  1. eelfner
    eelfner Curious Dude
    Cincinnati
    My Prius started misfiring. Replaced the plugs today. Looks like it was time! So easy! Why did I wait? IMG_4166_HEIC_and_IMG_4167_HEIC.jpg
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    150,000+ or a shit load.
    Raytheeagle likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Those electrodes leave something to be desired:eek:.
    Somewhere near lunar is my guess:cool:.
    Why'd you wait:whistle:?
    edthefox5 likes this.
  4. AzusaPrius
    AzusaPrius Senior Member
    2,137
    904
    However many miles you have on it.
  5. JC91006
    16,674
    8,519
    I like the "don't fix it until it breaks" approach
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    Buildup like that isn't usually a mileage thing. That looks more like running significant additives in your fuel. Do you put anything other than gasoline into your tank?
  7. edthefox5
    10,096
    4,831
    Clearwater, Florida
    I think significant blow by doubt the owner of this car ever checks the oil bet
    It’s a LOEM.
    C Wagner likes this.
  8. eelfner
    Cincinnati
    Must be 214k.
    I bought the car used. The engine has been fine until recently. If I knew how easy the change was, I would have been on it long ago. The car burns a lot of oil and I have been debating replacing the engine, or giving the car away. When I started getting mis-fire codes, I decided to move forward.
    @edthefox5 I definitely stay on top of the oil and use Mobile 1 as it seems to burn comparatively clean. I've assumed the rings are gone. What's a LOEM, or am I embarrassing myself further by asking?
    @trm-JWRP I did run 2 cans of BG: EPR just to see if it would help with the oil consumption (no help), but would not expect that to leave deposits.
    Very impressive to me that car ran so well on these old things. 45MPG
    There is a great out-of-the way shop that works on Prius's that would put a used engine in for under $3k. Just seems risky as the drive battery probably has 0-3yrs left and no telling what else might go soon, CVT... I have been holding out to get a Chevy Bolt, but waiting for the prices to drop which has started. Seems the 2017s are coming off leases now.
    Off to change the plugs in my 2007 Prius and will go ahead and get another set for my sons 2005...
    C Wagner and AzusaPrius like this.
  9. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Exactly.
    Little. Oil. Eating. Monster.
    Your calculations on how many ways to lose at this point are pretty right on. Just keep the oil at the full line use a 40 weight oil to mitigate the oil loss stop using Mobil 1 that’s a waste of money and take it easy on the car till it explodes.
    It’s the toughest little car ever it may surprise you but like you said your staring down the barrel at the hybrid battery like the rest of us. Don’t put any more money into it.
    #9 edthefox5, Jul 25, 2020
  10. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Btw used engines are plentiful for a G2 and not that bad haven’t looked lately like $500 and labor based on the many I have seen on this site is like $1000 to 1500 ymmv.
  11. C Wagner
    C Wagner Member
    183
    58
    Boston
    A failed hybrid battery isn't beyond a DIY-er with some soldering/basic electrical skills - Even if you ask an independent to switch in a better/rebuilt HV battery, the cost isn't that terrible $700-1500 I'm guessing, less if you simply bring them your bad HV battery and take a good one and do the install yourself.
