How many pumps on the 3rd Gen Prius ???
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PRIUS STAR SHIP, Jun 16, 2017.
  1. PRIUS STAR SHIP
    PRIUS STAR SHIP Junior Member
    34
    17
    I'm assuming the 3rd Gen Prius has two pumps, one pump for the engine coolant and the other pump for the inverter coolant ???
    Please correct me if I'm wrong, should I preventively replace both of those pumps ???
    Does NutzAboutBolts have videos on this ???
    Below are some videos towards the right direction:
  2. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Hmmm. I would NOT do preventative maintenance on those items. I would WAIT until those items actually failed.
    Best of luck to you.
    Ron (dorunron)
  3. Mendel Leisk
    38,875
  4. Rebound
    Rebound Senior Member
    3,964
    2,615
    Portland, OR
    And an oil pump and an AC compressor...
  5. mjoo
    mjoo Senior Member
    1,130
    1,319
    Michigan
    Add fuel pump, a small tranny pump (0.4 PSI). Windshield wiper pump.
    VS985 4G ?
    Rebound likes this.
  6. mjoo
    mjoo Senior Member
    1,130
    1,319
    Michigan
    Almost forgot the most important one - the brake booster pump. There'd be no ABS without it...
  7. Mendel Leisk
    38,875
    That's the expensive one? (n)
  8. mjoo
    mjoo Senior Member
    1,130
    1,319
    Michigan
    Yeah, it will cost you your first-born if it fails.
    There's also electronic pumps that convert your traction battery voltage ~210 V to ~600VAC for driving the electric motors. :eek::confused::eek::confused:
