How many unique smart keys for Prius?
Discussion in 'Gen 2 Prius Technical Discussion' started by 2009Prius, Aug 26, 2010.
  1. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Just heard on cartalk radio that there are a limited number of mechanical car keys so there is a chance that someone may unlock and drive away a car that does not belong to him/her. Would the same happen with our Prius with smart keys or does each Prius has its own unique code?
  2. Patrick Wong
    18,198
    6,464
    Each fob has a unique code and the Smart-equipped Prius can recognize up to five fobs.
  3. cproaudio
    cproaudio Speedlock Overrider
    2,401
    758
    CA
    This is so true. At my last job I remember we worked on a late 80's Ford F150 and a late 80's Escort. I grabbed the wrong keys but it worked. Keys from both vehicles work on each other, locks and ignition.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    The number of possible smart keys is finite, since it is a fixed number of digits. On the other hand, the number is so large that a code is never reused.
    Tom
  5. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    954
    716
    Boulder Hybids, Boulder, CO
    The immobilizer on the Prius Gen2 is very sophisticated, so much that the powers that be gave Toyota an exemption on locking the steering column.
    Compare to pretty much every other car made since the 70's, you can always steer the Prius wheels, with or without the keys.
    But good luck getting a Gen2-3 out of Park and/or getting it into Ready mode unless you have a valid FOB.
    Compare to:
    Gen 1 steering column is locked unless you have key.
    Gen1 has a mechanical override to get shifter out of Park. (Remove small rectangular plastic cover under the steering column (it's about the size of your finger), press finger in hole, move shifter)
