How much ATF ws should i buy for pruis v 2014
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Dusty rug, Jul 14, 2020.
Tags:
  1. Dusty rug
    Dusty rug Member
    47
    32
    Colorado
    2014 Prius v wagon
    im looking to change my ATF ws with the OEM stuff but im wondering how many quarts does it take to change out the fluid. i tried looking else where on the forum but i cant seem to find that answer.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    4 quarts;).
    Remember to open the fill plug first:).
    Good luck with the fluid swap(y).
    #2 Raytheeagle, Jul 14, 2020
    SFO, jzchen and edthefox5 like this.
  3. Dusty rug
    Dusty rug Member
    47
    32
    Colorado
    2014 Prius v wagon
    thanks for the quick respawns! alright looking to do my first flush, so wish me luck!
    Raytheeagle likes this.
  4. Mendel Leisk
    40,584
    Yes 4 quarts will do. Refill with the car raised and level. I've found a funnel with about 3 foot of hose (keep hose OD to around 5/8" max to ensure it'll fit in the fill hole with a little play) is very easy, especially if you've got an assistant to pour. Just go slow with the last quart. When fluid starts coming back out level is correct. Torque for both fill and drain bolts is 29 foot pounds. A 10mm male hex "socket" is need for both fill and drain bolts (they're socket-head-cap-screw style) Toyota recommends to only use Toyota ATF WS, from freshly opened bottles (don't save left-over).
    Tim Jones likes this.
  5. RAM v
    RAM v Junior Member
    72
    St. Paul, MN
    2014 Prius v wagon
    I did a tranny fluid change at 30K miles and it was quite easy. Glad I did as I was surprised how dirty looking he original fluid was. As described, a hose and funnel for refill worked fine. Good tip about making sure you can get the fill plug loose BEFORE you drain the fluid.
  6. Tim Jones
    Tim Jones Senior Member
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    you ought to see how it looks and smells with 200,000 miles.......
    ttou68 likes this.
  7. ttou68
    ttou68 Active Member
    351
    209
    I did one with 253K on the clock, and the color match the paint color of the car.. Winter Grey... But never tried to smell it tho.. LOL
  8. Mendel Leisk
    40,584
    Not sure, but my hunch: if you do an initial transaxle drain and fill around 10~20K miles, and then let it be till 200K, it wouldn’t be nearly as discoloured.
