How Much Charge Should Battery Take?
Discussion in 'Gen 2 Prius Audio and Electronics' started by kenmce, May 7, 2004.
  1. kenmce
    kenmce High Voltage Member
    1,534
    508
    NY
    I just got an '01 Prius. I can't seem to get the charge indicator for the big battery above the 3/4 mark. It gets as high as the +/- signs and doesn't seem to go any higher.
    If the car is parked and idling, shouldn't it automatically top up the battery to the top of the indicator? How do I top off the battery? Once full, how long should it stay that way if the car is left parked?
  2. siai
    siai Junior Member
    50
    Florida Keys
    The battery should never reach a full state of charge in the Prius. The reason for this is that if the generator (MG2) in the Hybrid system fully charged the battery, then there would be no place to store the re-generated energy when the vehicle was driven. The energy used (fuel burned) to charge the battery would be wasted. The charging system uses an very complex algorithm to determine state of charge based on several factors including voltage rise, cell temperature rise and charging current. I believe about an 85% state of charge is the point at which charging ceases.
  3. siai
    siai Junior Member
    50
    Florida Keys
    Oops! I said MG2 is the generator that charges the battery when the engine is running----Should have said MG1. MG2 is the main drive motor while MG1 is the smaller of the two. That's why I am still a Rookie poster :D
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Takes a while to get used to the MG1/2 roles. MG2 does provide generation, but only in regenerative braking, and possibly in the "heretical overdrive" mode that some believe exists :)
  5. john1701a
    john1701a Prius Guru
    12,760
    5,246
    57
    The extremes of Minnesota have steep & length decents into valleys. Driving down into them was the only time my 2001 Prius ever exceeded the 3/4 mark.
    Dropping to 1/2 from time to time was normal.
    Dropping to 1/4 (or lower) never happened.
    So what you are seeing is what the system was designed to do for typical use.
  6. Ralphmc
    Ralphmc Mr Hybrid
    37
    Nashville, TN USA
    kenmce,
    Here are some real life examples. My first experience with the "battery charge" was at the dealer ship. I was ready to pick up my car, and the sales man said I would have to wait a few more minutes, since they would have to get gas to put in it, and would have to drive it for 30 miles to charge up the batteries. I was shoked, and told him, that I can do that my self, so they deceided to skip that part. Got to the car, and the battery indicator showed half full, not as I expected some where in the read below last mark on the bottom.
    My second experience on the "battery charge", was when I was going down hill for several miles and had quite frequently used the "B" mode instead of using the breaks. I observed that the battery charge indicator was filling up the last segment at the top, and all of the sudden I could feel less breaking torque comming from the enigne, and the engine started spinning up to an extreemly high RPM, so I deceided to not continue using the "B" mode / only for the rest of the trip.
    I do believe that by design the Toyota concept includes some means of heat - resistive system, why else would the Batteries get so hot that they need external ventilation... Also keep in mind that only 30% or so of the kenitic energy can be recover by means of "regernerative" breaking, so it will take quite a bit of breaking to get the batteries in top charge stage.
    So far I have gotten the battery charge indicator from 2 bars above 0 to all bars green, but most of the time I now learned to operate the car so that the battery charge is one or tow bars over the 1/2 mark, during any commute.
    Sorry for lengthy reply, but I feel like this can not be explained in enough detail.
    Ralph
  7. HTMLSpinnr
    5,341
    920
    251
    I'm not sure they would use heat resistance on purpose, rather it's a byproduct of forcing chemical change within the battery pack. The charging/discharging process is not 100% energy efficent - some is lost as heat through resistance.
    As for the my '02 - I saw it at 1/4 a few times (going up a mountain), and I got it completely full once or twice - but only coming down a mountain grade.
    The '04 - I see near full or full much more often, sometimes my morning commute will get me near full on the descent.
