How Much Does it Cost to Charge?
Discussion in 'Prime Plug-in Charging' started by Tideland Prius, Jul 20, 2018.
  1. Tideland Prius
    16,398
    Electric
    MPGe Le/100km kWh/100 miles kWh/100km
    1 133 1.8 25.34 16.02
    Gasoline/Petrol
    MPG L/100km kWh/100 miles kWh/100km
    1 54 4.4 62.41 39.16
    Assuming:
    EPA all-electric range (AER): 25 miles or 40 kilometres
    Rated fuel tank size: 11.3 gallons or 43 litres
    When the low fuel light comes on: 9.2 gallons or 35 litres
    Actual kWh of battery charge from "normal"* hybrid battery SOC to full charge: ~5.5kWh
    Wall outlet readout of kWh of battery charge from "normal"* hybrid battery SOC to full charge: ~6.3kWh
    *Normal being 6 bars out of 8 for Gen 1/2/3 Prius drivers or about 3/4 of the hybrid portion of the battery indicated on the onboard display.
    The EPA uses 33.7kWh per gallon of gasoline for their conversions (8.9kWh per litre of petrol)
    Therefore, if you want to calculate your cost, let
    A = electricity cost in dollars per kWh
    B = Gasoline cost in dollars per gallon
    C = Petrol cost in dollars per litre
    $ = Cost
    Use the following formulas:
    1. For cost of electricity per EPA charge
    $ = A*25.34/4 (for 25 miles), $ = A*16.02/(100/40) [for 40km]
    2. For cost of electricity per EPA charge per mile/kilometre
    $ = A*25.34/100 (in miles), $ = A*16.02/100 (in kilometres)
    3. For cost of gasoline per full 11.3 gal/43 litre tank
    $ = B*11.3 (for gallons), $ = C*43 (for litres)
    4. For cost of gasoline per real life tank (i.e. refuel at the low fuel light)
    $ = B*9.2 (for gallons), $ = C*35 (for litres)
    5. For cost of gasoline per mile/kilometre
    $ = 1/54*B (for dollars per mile), $ = C*4.4/100
    Example:
    A = $0.1/kWh
    B = $2.499/gal
    Therefore,
    1 = $0.634 (or 63.4 cents) per 25 mile charge
    2 = $0.025 (or 2.5 cents) per mile
    3 = $28.24 per full tank of gas
    4 = $22.99 per tank of gas if you refuelled at the low fuel light
    5 = $0.046 (4.6 cents) per mile
    At 10 cents per kWh and $2.499/gal gas, you're saving almost 50% by using electricity. (46% to be exact).
    If you travel 500 miles a month:
    And you used electricity for all of those 500 miles, it would cost you $12.68.
    And you only drove in hybrid (HV) mode and never charged, it would cost you $23.00
    AAA, CHIZ, Inspectorman and 8 others like this.
    50,789
    that's it!(y)
  3. Estew808
    Estew808 New Member
    Santa Monica, CA 90404
    2018 Prius Prime
    This a great post. Thank you! :)
    I picked up my car yesterday. I sold a Hemi powered Chrysler to pay for it... :eek:
    I haven't found all the free charging spots in my community, but for fun, I tried the "Charge-Point" system at my office. They charge what amounts to $0.36 / kWh for Level II charging. That is not a terribly attractive option. :whistle:
    Thanks again for your post!
  4. ziggy29
    ziggy29 Member
    127
    64
    North Oregon Coast
    2018 Prius Prime
    Yep. That equates to roughly 9 cents per mile under EV power. At 50 MPG in HV mode, gas would have to cost more than $4.50 a gallon for this to make purely financial sense to charge up.
    Estew808 likes this.
  5. triggerhappy007
    triggerhappy007 Active Member
    498
    334
    Did you know you get $100 to use at ChargePoint when you buy a new prime? Just put your VIN for the promo code when you sign up. At least you can get some free charging for a while.
    ColoradoCrow, Ek37 and Estew808 like this.
  6. ziggy29
    ziggy29 Member
    127
    64
    North Oregon Coast
    2018 Prius Prime
    Pretty sure this was only for the 2017 models.
    benagi likes this.
  7. triggerhappy007
    498
    334
    You are right, I didn't even see the year because I was on mobile.
  8. Estew808
    Estew808 New Member
    2018 Prius Prime
    They gave me $10, but I didn't put in my VIN. $100 is a nice promo! haha
  9. eric4214
    eric4214 Junior Member
    Atlanta, GA
    2018 Prius Prime
    The $100 Gift Card only comes with / came with the 2017 Prius Plug-In/Prime. It is not available for new models later than 2017.
  10. DonJ
    DonJ Junior Member
    Fremont, CA
    2019 Prius Prime
    Your note states that a full 25-mile charge is achieved with 6.3 kW-h input. But my Prime has a 8.8 kW-h battery.
    In my calculations I use 8.8 kW-h. Is this wrong, because the 8.8 kW-h battery is never fully drained?
    Also, can you clarify where 25.34 comes from:
    Also, is it correct to think of the Prius Prime as a Prius with a much larger traction battery? Or is the extended EV range achieved in another manner?
    Thanks,
    Don
    #10 DonJ, Jan 21, 2019
  11. Tideland Prius
    16,398
    Correct. 8.8kWh is the total capacity of the battery but Toyota does not use the entire range. The actual capacity used for the EV portion is approximately 5.5kWh but due to losses to heat when you charge, you will see closer to 6.1-6.3kWh on a meter when you fully charge the car and that's number we use for cost since that is what you will be charged by your utility company (6.1-6.3kWh).
    25.34 is the kWh/100 miles.... the "fuel" consumption. (like.. gallons per 100 miles or litre per 100 km)
    Yes and no. Yes in the sense that once you exhaust the 25 mile range, it reverts to hybrid mode so it's like a Prius with extra capacity (great for going down a mountain or coming down from a ski hill!).
    The extended range is done via external charging but you can charge with the engine if you wish. Press and hold the HV/EV button to enter CHG mode. It's best to do it between 35-45mph (so country roads or flat highways) for best fuel efficiency vs. EV miles gained. You can, of course, do it at any speed if you wish to do so.
  12. Salamander_King
    Salamander_King Senior Member
    11,001
    8,922
    New England
    I have seen in many threads here regarding PRIME charging mentioning average use of electricity for full charge is 6.1-6.3kWh at wall. I think this number is true for L2 EVSE. However, I have been using Kill-a-watt meter almost two years now and recording my at wall charge by OEM L1 EVSE each time. For zero EV range to full charge, at wall reading has been always 6.5-6.8kWh. This value has been very consistent. Is my Kill-a-watt meter off or is this normal efficiency difference between L2 and L1 EVSE?
  13. CraigM
    CraigM Active Member
    208
    208
    Portland, Oregon
    The way I look at it is that your Kill-a-watt is reading the battery PLUS the current used by the EVSE itself.
    Salamander_King likes this.
  14. Marine Ray
    Marine Ray Senior Member
    1,139
    943
    Sparks, NV
    Home charging rules. I pay 5 cents/KWH here in Northern Nevada utilizing our power company's Time of Use program. Works out to about 1 cent/mile.
    jb in NE likes this.
  15. Marine Ray
    1,139
    943
    Sparks, NV
    Why not make number 5 - .0185 x B
  16. Salamander_King
    11,001
    8,922
    New England
    That might be the case. If true, then even with L2 EVSE there should be some electricity used by it if measured at the wall. If I understand it correctly, most of the reported L2 EVSE electricity is by EVSE itself. So it is not really measured at "the wall" value.
  17. Tideland Prius
    16,398
    The most I’ve seen from a public ChargePoint site the one time I charged to full from empty was 6.45kWh.
    I’m not sure what the difference is. We’ll need more data points - more people using kill-a-watt to report their findings.
    Cause I wanted it to be easy to follow. Someone reading it can see where I got the “54” from. Or “I’m showing my work”
    Marine Ray and Salamander_King like this.
  18. CraigM
    208
    208
    Portland, Oregon
    An interesting test would be picking up the EVSE brick in your hands just before your car obtains a full charge. I’d bet the brick would be warm to the touch indicating some power wasted as heat.
  19. Salamander_King
    11,001
    8,922
    New England
    Yes, it is warm. I am not disputing the fact that there is current that goes through EVSE and cord as well that waste some electricity. I am just wondering why the number I read off of a Kill-a-watt is 5-10% higher than what has been reported by others.
  20. KP7
    KP7 Member
    50
    42
    New England
    2018 Prius Prime
    Are you seeing any difference winter vs. summer with the need to get the battery up to temp to charge?
    I'm seeing about 6.5 as well with a level 1 at 8 amp. But it's a bit of an estimate as it is from a whole house monitor (overnight with little other load--compared pre- vs post-prime).
