How much gas is left in the tank when the light comes on?
Discussion in 'Gen 4 Prius Fuel Economy' started by krmcg, Oct 10, 2016.
  1. krmcg
    2,592
    2,390
    Whittier, CA
    In my experience, I have determined that my 2016 Prius has about 1.75 gallons of usable gas left in the tank when the light comes on. This table from "Your Mechanic" provides a close confirmation of my opinion. (Although the miles per gallon is considerably less than I am able to achieve).
    How%20Far%20Can%20You%20Drive%20Your%20Vehicle%20on%20Empty%20-%202%20chart%20REVISED.jpg
    https://www.yourmechanic.com/article/how-far-can-you-drive-your-vehicle-on-empty-by-brady-klopfer?utm_campaign=Weekly+Digest+10.10.16+OUT+OF+Service+Area+%28tNENHT%29&utm_medium=email&_ke=a3JtY2dAbXNuLmNvbQ%3D%3D&utm_source=10.10.16+OUT+OF+Service+Area
    #1 krmcg, Oct 10, 2016
    RCO likes this.
    49,371
    isn't it in the o/m?
    RCO likes this.
  3. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    FWIW my Prius v Three gas light came on the other day while on the way home from Dallas. Based on the quantity of gas I filled up with the tank had 1.92 gallons left in the tank. The light came on as I was going down a short hill towards the station after I got off of the interstate highway if that matters.
    krmcg likes this.
  4. GaryD1
    GaryD1 Active Member
    302
    138
    Seagrove, NC
    My experience so far has been that I can get close to 11 gal of gas in car when light comes on. If there is 1.6 gal of usable gas left, then that would mean that my tank and filler neck will hold 12.6 gal. I'm using different pump so they can't all be calibrated wrong, or my gas tank reading is wrong. I put 10.7 gal in last week and light had not come on. stopped at first click pumping slow.
    RCO likes this.
  5. ongbenghui
    ongbenghui Junior Member
    Singapore
    Was there a guideline of around 10% of fuel left for the warning light to pop up ?
  6. Elt31987
    Elt31987 Active Member
    205
    149
    Derry, NH
    i dont like getting this low, but my last fill up was at 3 miles to empty (DTE) and 9.9 gallons went in.
    BruceInOKC likes this.
  7. GaryD1
    302
    138
    Seagrove, NC
    I can put 11 gallons in my 2016 pumping slow, stop at first click at 3 miles to go.
  8. sjr14221
    sjr14221 Member
    115
    28
    WNY
    Four Touring
    Four tanks into ownership, I've only been able to get up to ten gallons in the tank one the light has come on and the trip screen tells me I have zero miles left. And unlike my gen two, when the gas pump clicks off, the tank is fill. No topping off - much to my horror as gasoline spilled down my shiny new paint!
    Previously, I could expect to go at least another 80 miles when the light came on. Will have to test the limits for this new car. Ok, so I didn't actually answer your question....sorry!
    RCO and krmcg like this.
  9. raspy
    raspy Senior Member
    438
    699
    London, UK
    This is an interesting review from Autotrader in South Africa, the reviewer actually managed to drive an additional 80km, after the DTE was down to 0km.
    RCO, BLITZ XW50 and Elt31987 like this.
  10. KV55
    KV55 Member
    126
    43
    Northamptonshire, UK
    Excel
    I have been slowly matching my bravery to my curiosity and at my last refueling I drove into the petrol station with 1 mile DTE showing, the low fuel warning light had been on for about 25 miles. I added 38.4 litres with a couple of clicks and that points to 4 litres remaining, bearing in mind not all of this will be available but clearly there are more than 20 miles in there (on a warm engine).
  11. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    I hope you carry a fuel can with at least 12 litres of petrol. In the US Generation 3 Prius, people found you needed to add 3 US gallons after running out of fuel.
    greenmonster01 likes this.
  12. KV55
    KV55 Member
    126
    43
    Excel
    How far had those people gone on the reserve? The four litres I am seeing would give me another 68 miles but the question is how much of that fuel is available, surely not all of it. If I found myself on the wrong side of the DTE-zero I would be confident of making another 20 miles, which can be the distance between petrol stations in the rural areas.
  13. Mendel Leisk
    38,644
    Maybe this thread is in the wrong forum? Apart from slight weight reduction as you near empty, I don't see any mpg advantage, to running the tank near-dry. Maybe Priuschat needs a "Darwin Awards" forum?
    axle2152 and RCO like this.
  14. Prodigyplace
    11,696
    11,318
    Central Virginia
    What sort of award for @bwilson4web then? "Devil for Punishment"? :D :LOL:
  15. fuzzy1
    10,149
    'Rural' means different things in different places:
    Even the Trans-Canada Highway has a similarly long segment without fuel, from Golden to Revelstoke.
    RCO likes this.
  16. RCO
    RCO Senior Member
    3,709
    5,183
    Cornwall
    I like your thinking, but the DARWIN AWARDS are reserved for those successfully removing themselves from the human gene-pool by inherntly foolish and unnecessary means. Thereby removing an irrelevant mutation from further breeding stock. :rolleyes:
    Darwin Awards. Chlorinating The Gene Pool.
    #16 RCO, Jun 20, 2017
    fuzzy1, Prodigyplace and Mendel Leisk like this.
  17. greenmonster01
    106
    79
    Southeastern MA
    Good to know... My spare gas can is only 2 gallons :(
  18. bisco
    49,371
    and make sure the spout fits through the inside flap, some are too large in diameter.
    Prodigyplace likes this.
  19. bisco
    49,371
    no problem, there's plenty of petrol left ate dte=0. pip has 2+ gallons. i rarely fill up before the last bar flashes, but it's only a 10 gallon tank.
  20. KV55
    KV55 Member
    126
    43
    Excel
    As an observation the DTE miles are short so if it says 50 miles to empty and you have 50 miles to go the fuel won't normally cover it. I went four miles past DTEzero at the last refuel, the DTE display changes to a series of dashes --- so if this happens you need to set a trip counter to keep track of where you are.
