How much weight can a prius tow in a trailer?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ski.dive, Mar 27, 2012.
  1. ski.dive
    ski.dive Active Member
    896
    231
    Hutchinson Island,FL. Mt. Snow,VT
    LOOKING TO GET A SMALL TRAILER FOR MY PRIUS.
    HOW MANY POUNDS MAX. CAN THE PRIUS TOW WITHOUT CAUSING ANY DAMAGE TO THE CAR MOTOR OR TRANNY?:confused:
    WHAT'S A GOOD LIGHTWEIGHT TRAILER TO GET?
    PLEASE REPLY ONLY IF YOU HAVE TOWED A TRAILER WITH YOUR PRIUS.
  2. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    I tow a 5X10 landscape trailer with 2 yards of mulch on it a few times every year, and I use it occasionally to haul 4X8 sheets every once in a while. It tows like it's not even there when it's empty.
    That said ... the lighter the better. Harbor freight's cheap, lightweight trailers work just fine and fold up to put in your garage. I wouldn't overdo it in terms of how often you do it, and I wouldn't overload it either ... instead make 2 trips if necessary. HF has an 1100 lb capacity trailer for right around $300, and with a 20% coupon you can get it for about $240. They're fine for light duty occasional use, especially if you can keep them inside out of the weather.
    Toyota says you should never tow anything. I just do things within reason. Not really worried about it for as often as I do it. Maybe 20-30 miles per year total in 2 or 3 trips.
    REV
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Technically, legally, zero.
  4. revhigh
    986
    141
    Yeah ... we all know that. :D
    REV
  5. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
  6. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Nothing illegal about it.
  7. Eoin
    Eoin Active Member
    593
    116
    Long Island
    I'm sure it would void any warranty.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    This is another "snakepit" question, that creates controversy in asking and reply.
    Toyota recommends not using The Prius to Tow...PERIOD.
    And yet? Even though we all supposedly know this, not only does this question continue to be asked and debated, people do use their Prius to Tow.
    I think the most correct answer to the question "How Much Weight Can A Prius Tow In A Trailer?"
    Is, Toyota isn't saying, because Toyota doesn't want you towing any weight with a Prius.
    So How Much Weight are you willing to "Risk" Towing with your Prius?
    That opens up the debate between the realities of what has been done by others, how many times it has been done, and what it might mean to any warranty coverage if somehow someone had a failure and Toyota discovered the vehicle had been used in towing.....
    Good Luck With That....
    My general feeling is that if towing a lot is a life priority? Don't buy a Prius. If towing is a big priority? Prius is the wrong tool for the job, even if you CAN get away with it to a degree.
    JohnMichael likes this.
  9. revhigh
    986
    141
    So ... ALL you guys responding have 'TOWED A TRAILER WITH YOUR PRIUS' as the OP requested ???? :D
    REV
    Rmay635703 likes this.
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    If the PSD went TangoUniform you wouldn't have a legal-foot to stand on going after Toyota to fix it under warranty. Just saying.
  11. The Electric Me
    9,083
    5,798
    Phht...you ask a question in a open forum? Don't go attaching caveats to it.
    You want to discount my response because I haven't towed a trailer with a Prius? Go Ahead.
    But Toyota doesn't recommend using a Prius to tow. Therefore...there is no factory provided stats as to how much weight a Prius can tow...so any answer from any individual is based on simply there own experience and opinion about towing or not towing.
  12. revhigh
    986
    141
    First of all ... I didn't ask the question, but I have a feeling that some of the responses given so far is the EXACT reason the OP 'tried' to put that caveat on his question.
    To the OP ... try the link below ... for further information in answer to your question ... and less preaching about what you should and shouldn't do. You may have to join to read everything, but it might be worth it. It's a whole newsgroup related to towing with a Prius.
    priustrailers : The Toyota Prius Can Tow a Trailer!
    Again ... yeah .... we got that .... Toyota doesn't recommend that you tow .... OK.
    REV
  13. bedrock8x
    bedrock8x Senior Member
    1,483
    137
  14. revhigh
    986
    141
    Yeah ... I wouldn't go THAT far .... LOL !! :D
    REV
  15. Former Member 68813
    3,524
    981
    US
    IMHO The topic should read:
    How much weight can a prius tow in a trailer safely and at what speeds?
    or
    How much weight and at what speeds can a prius tow without shortened life penalty?
    full disclosure: I don't tow with Prius. I tow a 17' boat with RAV4.
  16. revhigh
    986
    141
    Interesting questions, but no way for definitive answers.
    The best anyone can come up with is common sense and reasonable solutions. Everybody has their own threshhold for risk, and everyone's towing requirements will be different. In my case, a few times (with light weight) a year is all I need, and I'm comfortable with that. If someone needs to tow a pop-up or a light boat every weekend of the year 50 miles each way, then they bought the wrong car. I wouldn't tow a pallet of cinder blocks 5 blocks with a Prius, even if I could, but that's just common sense. For towing a few kayaks or bikes occasionally, or maybe even a broken down motorcycle a half dozen times a year ... there's no issue
    REV
  17. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Isn't this like asking if it is OK to kill a man and asking that only people who HAVE killed a man answer?
  18. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Good question... have you? :eek:
  19. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    No, the most sickening thing I ever had to do was kill someone's horse that had fallen (on a hillside 17 miles from a road) and broken two legs, with an axe.
  20. Former Member 68813
    3,524
    981
    US
    you didn't need to answer this question.
    Jerry Mcl likes this.
